Ballast blades
   / blades #2
according to my BX document I have, Some one on TBN, I forget who it will fit. I attached the document for your review. Look at the bottom of the list, its the blade you are referring to.
  • BXGatorBlades.pdf
   / blades
The only difference I see is OEM is 7/8 and Gator is 29/32. Would the difference(1/32) make it a problem?
   / blades #4
I honestly don't know. I never ordered them nor used it yet. When I step back and think about it, 29/32 is 1/32 larger then oem 7/8 in turn that is 1/64 gap all the way around the shaft. The mower bolts holds the blades from turning, I remember my OEM blades when I put it on has very very very little play- its not really a play in space but can be turned around around on the shaft before its tightened up.
IMHO, I really doubt there would be any vibration from the blades with all 3 blades 1/64th off centered. Heck- I can't even measure 1/64th on a peice of metal from my lumber measureing tape. If there is any vibration, it would be from not balanced after from resharpening the blades.
IMHO again- I'd order the set of gator blades in a instant, no worries. :thumbsup:
   / blades
Thanks. Will probably try them.
2026 Anvil T/A Enclosed Trailer (A56859)
2026 Anvil T/A...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
