Ballast blades
   / blades #2
according to my BX document I have, Some one on TBN, I forget who it will fit. I attached the document for your review. Look at the bottom of the list, its the blade you are referring to.
  • BXGatorBlades.pdf
   / blades
The only difference I see is OEM is 7/8 and Gator is 29/32. Would the difference(1/32) make it a problem?
   / blades #4
I honestly don't know. I never ordered them nor used it yet. When I step back and think about it, 29/32 is 1/32 larger then oem 7/8 in turn that is 1/64 gap all the way around the shaft. The mower bolts holds the blades from turning, I remember my OEM blades when I put it on has very very very little play- its not really a play in space but can be turned around around on the shaft before its tightened up.
IMHO, I really doubt there would be any vibration from the blades with all 3 blades 1/64th off centered. Heck- I can't even measure 1/64th on a peice of metal from my lumber measureing tape. If there is any vibration, it would be from not balanced after from resharpening the blades.
IMHO again- I'd order the set of gator blades in a instant, no worries. :thumbsup:
   / blades
Thanks. Will probably try them.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2016 Chevrolet Tahoe SUV (A55973)
2016 Chevrolet...
2013 Nissan Sentra Sedan (A56859)
2013 Nissan Sentra...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56435)
2019 RAM 5500...
