Mowing Blades for mower
/ Blades for mower #21
Have you got a hacksaw?? Thats all it takes. If you don't have a vice to hold the bushing, hold it down on a block of wood with the FEL. If no FEL, put it between two boards and drive the tractor up on the boards.
ron
/ Blades for mower #22
I also cut my adapters with a hacksaw, no problem. They don't ned to be perfect. The Gater blades do a great job. Get them & you won't look back.
/ Blades for mower #23
I just bought a set of gator magnums on ebay, I'll give them a shot before I go to the mulching kit. They aren't that expensive so it's worth a try to me.
/ Blades for mower #24
Anyone know why the blades for my BX2200 RCK60B-22BX 60" mower cost about twice as much as the ones for a B series RCK60B-24B 60" deck? I was going to look for a high lift set for my deck when I saw maxqwest paid less then $12 per blade. A standard blade for mine is over $20 and I don't know if there is a high lift blade for this deck.
/ Blades for mower #25
Many of the Kubota decks have different blades available for them. Some are original stock which is more money and then there are what I call the economy blades.
There is a difference in the part numbers as well as the price but I don't have them handy right now. Day time I can get them for you!
149's are great!
/ Blades for mower #27
I am not sure about the bx 60 inch mmm,but fit the rck60-24b, (+1/8 inch) length and same hub size.I know the manual states 20.60 in. length,but they work off the metric system.My stock blades are 20 and 5/16 inches long the 70000-25011 high lift blades are 20 and 7/16 inches long,1/8 inch longer.Hub or hole size is 1 and 1/8 inch wide on both,1.125, .250 thick.I hope this may help.The high lift blades work great for me. $12.00 each works good too.
/ Blades for mower #28
I followed volfandt's advice & ordered my gator blades last fall. I did not get around to installing them till a few weeks ago. I cut the bushings with my reciprocating saw, using the metal cutting blade. It wasn't a pretty site, but the end result works just fine.
And, yes, I like the cut.
I had saved Vonfandt's original post as a 'favorite post' & referred to it when ordering. What happened to the favorite post feature??? Guess I don't check out my TBN 'home' very often.
/ Blades for mower #29
Add me to the list of folks who think Gator Blades are a wonderful thing! :D I also followed Volf advise on using the bushing from a cat 1-2, worked great. The cut is just great, no more tire pushing the grass down and not being cut. My daughter was kicking a soccer ball around after I got done and even remarked how nice it looked and NO grass clipping mounds.
If u are on the fence trying to decide, go for it.:)
/ Blades for mower #30
Hi Tom,
You probably have the same mower deck that I have-RCK60B-22BX. Could you tell me the part number of the gator blades you bought for yours and how much they cost. Go SOX!!! ;^)
/ Blades for mower #31
Add my name to the list of happy Gator blade users. They are as good as everyone on here claims! No more grass knocked over by the tires, and I can mow as fast as my BX2200 will move in high range.
/ Blades for mower #32
149owner said:
Hi Tom,
The part # for the gatorblades is: 90-987
I got them here. Gator Blades - Gator Lawn Mower Blades - Gator Lawn Mower Blade - Mulching Blades - Mulch Blades
AND New Accounts recieve additional 10%
Place coupon code "1234" in box provided at checkout to recieve New Account discount of 10%:
/ Blades for mower #35
Thanks Tom!
/ Blades for mower #37
Just ordered a set too. Fast delivery (3 days). Price too good to resist.
Will put them on someday and spread the joy...
Russell in Texas
/ Blades for mower #38
My "Gators" are on their way and with all this rain I'd say it's just in time! Now I just have to go to the Stealer and get the bushing. Thanks again.
/ Blades for mower #39
Is any one using a Gator muching Blade with the 60B-23BX Mower on a BX24? I would like to change to the Gator blade if their is a blade that will fit this mower. If there is, could you give me the stock number for it.
/ Blades for mower #40
I'm sending the Gators I bought for my 54" P deck back. They don't fit, and I've been staring at 4 bushings and it still won't work, it's not worth the hassle or potential damage it could cause from a half *** fitment. When they decide to make blades that fit properly I'll buy them. On top of that the dealer will throw the warranty out if they see them there anyway. Thus far the gators have done nothing but waste my time.
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
CAT D11R Ripper Teeth (8) (A68134)
CAT D11R Ripper...
2020 JOHN DEERE 325G SKID STEER (A65056)
2020 JOHN DEERE...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
METAL SAW HORSE (A68842)
METAL SAW HORSE...
