Mowing Blades for mower
/ Blades for mower #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I'm looking for information on a new set of blades for my 60" deck on my BX. I was going to go for a Kubota mulching kit but I'm not heard good things on it. I'm looking for mulching blades however since I do want to chop the lawn up as much as possible. I'm a bit tired of the trails around the lawn. :)
On the blades, preferably something that is a direct bolt on.
/ Blades for mower #2
There has been a lot of discussion on this board in the past about "gator blades". If you do a search you should be able to find plenty of information about them including the where to order them online.
There are a few posts describing how to make them fit on the 60" bx mower deck. Here's one of them gator blades
/ Blades for mower #3
Scrounger said:
I'm looking for information on a new set of blades for my 60" deck on my BX. I'm a bit tired of the trails around the lawn. :)
Scrounger - I had problems with trails of cut grass, also. I changed to Kubota high lift blades and have been satisfied with the results.
I mow my 2 acre lawn with a B7500 and 60" ground contact MMM. I get the best cut by: 1) starting with a clean (underside) deck, 2) running high lift Kubota blades, 3) cutting at 3" height, 4) running engine at PTO speed (2,600 RPM), keeping ground speed a little slower than I would like to naturally run, 5) discharging clippings outward onto already-cut area, and 6) holding the discharge chute up with a bungee cord (need to be careful). I am satisfied with the cut that I get. When the lawn is very long, and/or wet, I either run back over any windrowing to disperse it, or pick it up with a pull-behind sweeper. Best wishes!
/ Blades for mower #4
I have been using the 54" MMM with mulching kit/high lift blades on my BX24 with excellent results. You do need to keep up with the mowing and if it gets a bit high go over it twice, once with the deck a bit higher, then again at normal height, but hey, thats more time I get to spend in the seat.
As suggested above, PTO rpms and drive a bit slow.
/ Blades for mower #5
You would say then that the mulching kit was worth it? Problem I run into is mowing around alot of our mulched areas, and trying not to blow cut grass onto the nice black mulch. I was thinking of just using a discharge cover but didn't know if that would do it.
I had looked at gator blades this morning on ebay, but was still thinking about a mulch kit.
/ Blades for mower #6
I have a 54"MMM on my BX1500 with the standard Kubota blades. Lift the chute deflector does help a good bit (once again be careful of others around you).
/ Blades for mower #7
IMHO the mulching kit was worth it. I never have to worry about the mulched areas unless I accidently cut the corners too close and swing the deck over them.
/ Blades for mower #8
I have got the 54" "finish" deck and mulching kit as well. I have not met grass that it could not cut in my lawn, and many times cut it wet. It also made quick work of the leaves this fall, and I have a lot of trees.
-dan
/ Blades for mower #9
Looks like I'll give the mulching kit a try, I think I was quoted $150 for since I have the 54" finish deck as well. Thanks for the comments.
/ Blades for mower #11
I have a b7610 with a rck60-24b mmm.As stated by another member I ordered from my kubota dealer,part number 70000-25011 blade set,(high lift).As member stated- WHAT A DIFFERENCE -same length,perfect fit.Cutting for me,less than full pto rpm,much better cut,saves me fuel(lower rpm).Got another set for spare,$12.00 per blade x3.
/ Blades for mower #12
What is the PTO speed for a BX23 with the 60" MMM?
/ Blades for mower #13
2500 pto rpm. In the case of no tach. Just under wide open will be about 2500 pto rpm,High gear position on pto lever,at least it is on my tractor.With these blades I get a better cut at 2100 engine rpm,than I did at 2600 engine rpm,(stated engine rpm for full pto rpm)with stock blades.
/ Blades for mower #14
Huh. You'd think they'd throw a cheap tach on these tractors for that kind of stuff then. Well, I'm off to tiny tach!! Hope the diesel one works better than the regular one does. (tried it on an older MTD and it wouldn't work half the time)
Thanks for the info!!
/ Blades for mower #15
Newbie question, sorry, may be stupid.
I got a brand new BX2350 with the 60" MMM last week.
I have not tried to cut grass with it yet but I felt the blades as I was inspecting it and they felt very dull. I remember handling sharpened blades in the past...they are at least dull kitchen knife sharp. These seemed slightly rounded at the end. The dealer told me not to worry about it, that they don't come very sharp from the factory, that it spins very fast compared to older lawn mowers.
Obviously they are either going to cut well or not, but, should they be sharper seeming? I can't believe they come that way from the factory. Was the dealer screwing me by putting old blades on the tractor or something?
Thanks in advance.
/ Blades for mower #16
When I got the MMM for my BX23, it was the same thing. I'm not sure why they come that dull. It's not like its a bush hog. :p I yanked mine and ran an edge onto them with the bench grinder. The other thing is they crank those **** bolts in. I used a 3 ft+ breaker bar to break them loose the first time. Plus I got to get some grease on the bolts before they got any moisture in them. Makes taking them out later much easier.
If you want to, try it without sharpening them first, and see. If it doesn't seem to be doing a good job, yank em off and throw an edge on them. I'm switching over to the gator blades this season anyways. I didn't like the way the standard blades cut.
/ Blades for mower #17
So far I'm most impressed with the gatorblades. I mow at 3" and when I keep grass caughtup which is mowing atleast once a week around here, theres no need for a bagger or sweeper etc as the clippings are chopped up and disbursed quite well. I do build a compost pile each season so every 2 or 3rd mowing I'll side discharge into windrows and collect the clippings up. The gaterblades do well with the cyclone rake also.
I'm on my 2nd season with the gatorblades and I haven't had to sharpen them yet.....
Oregon which makes the gatorblades doesn't make a set that are direct replacement for the BX's 60" MMM but they do for the Kubota ZTR 60" mower. Unfortunately the center hole is too large for the BX mower. I did a post awhile back that listed hole sizes and part #'s but don't recall them off hand now.
Thats said, there is a fix, an adaptor if you will, that decreases the center hole down to the size needed to fit the BX spindle. The adapter is a simple Cat 1 to Cat 2 bushing adapter available at any tractor supply house. You only need one and you cut off two pieces that are just a hair thinner than the thickness of the blades. Works great and lasts along time :D
In any case, a mulching setup is good and the std blades are good too but i've found that in my case, the gatorblades work best for me.
/ Blades for mower #18
Scrounger and others,
I have the 54"MMM and purchased the mulching kit and blades with it.
If all I were ever doing was mowing nice lawn, PROBABLY the mulching kit would work fine. However, sometimes, I want to mow and discharge. The kit is NOT an easy on/off deal, though if you had the deck off, it is not difficult.
I don't know if the MMM has the kit holes in it or if you have to drill them, since mine was dealer installed. There are probably 10 5/16" bolts that hold on the shielding.
I've left my kit off, gone with the normal blades, and fabricated a metal cover plate that bolts over the discharge opening. It works acceptable for me.
You can do as you wish, but I'd recommend making a closure plate, buying some mulching blades, and see if that does the trick for you. It's a lot easier to take off two bolts that you can reach from the discharge area than those bolts all over the deck with the kit.
Ron
/ Blades for mower #19
I have a B7800 with the 60" Kubota mid-mount mower and have found the Gator blades to be terrific. I bought them through Agri Supply. I like them so much that I don't use them in my three set rotation as I had planned. Instead of taking off dull blades and replacing them with a set I have already sharpened I take the time to sharpen the Gator blades right then,
/ Blades for mower
Volfandt
Thanks for the details but I dont have anything that will cut those bushings precisely enough for it to work for me. I think the Kubota high lift blades are the only choice for me at this point.
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2013 KENWORTH T800 SLEEPER (A59906)
2013 KENWORTH T800...
240156 (A56859)
240156 (A56859)
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
2015 CHEVROLET SILVERADO 2500HD (A60736)
2015 CHEVROLET...
