blade on a string trimmer
/ blade on a string trimmer #1
stayalert
I was at a community event last Sunday sprucing up a cool old school house and property....One of the gals brought a really nice stihl trimmer with a balde on it....this blade has about 8 or ten teeth and appeared to be working very well.....Other blades I've seen had many many small teeth and one tool I used about 30 years ago had three teeth.....Whats the conventional wistom on blades for trimmers? I've got a beuty little shindiawa string trmmmer that I havn't p[ut the blade on yet.....Was thinkijng fewer teeth would be a whole lot easier to sharpen.....Whaddaya say?
Rob "stayalert" M
Norwich, VT
/ blade on a string trimmer #2
I don't know if more or less is better?
I remember my aunt only had 8 teeth but the dentist charged her the full price to clean em!.
/ blade on a string trimmer #3
/ blade on a string trimmer #4
Finally, a subject I can actually post an opinion on!:)
I use the brush knife (3 point blade) on my stihl brushcutter and it does wonders on blackberry vines. The interesting difference between this and a string trimmer is the motion--up down instead of side to side. Although it works with a side to side motion, it not only cuts but shreds in an up/down motion. Wear eye protection at the very least (I wear a chainsaw helmet--hardhat, ear protection, mesh faceguard).
Indeed. I also reccomend steel toed boots when using the bladed trimmers. In 1983 I was clearing a field with a bladed trimmer. I can hear the sound and see the toe of the boot I was wearing at the time. The trimmer hit the toe and put a nice clean slot right through the leather exposing and scuffing the nice steel toe....No injury but boy was I glad they required steel toed boots where I was working at the time.....
/ blade on a string trimmer #6
Your trimmer is designed to handle certain implements. I have Stihls. Some have an Autocut string head, others have a poly-cut head with the plastic knives and a piece of string, and then there are saw blades that we use as well as a power scythe, which is one of my favirites. I will even use an adjustable hedge trimmer head on my 85 to mow down tall grass and small brush. It just lays it down without making a mess. We also have some of the triangular brush blades but I personally don't like them...more like hacking and bushwacking and hard on the trimmer.
/ blade on a string trimmer #7
The 3 pt. blade is the best choice for things up to 1 inch diameter. I think it is also the hardest on your machine. The blade also tends to get out of balance if not sharpened evenly. If your cutting a lot of saplings get the blade that looks like a circular saw blade. It is easy to sharpen with a chainsaw file.
/ blade on a string trimmer #8
Don't ever put a fixed blade into your string trimmer unless you like trips to the Emergency Room.
I knowed this girl what had teeth like a mule. She could eat corn on the cob through a picket fence.
/ blade on a string trimmer #9
We use the Stihl disc blade that has teeth notched like a chainsaw blade's profile (but are not chain saw teeth...). You can resharpen it with a chainsaw file. It does a great job on bamboo, small saplings and bramble canes. It has been a great time saver but does require careful use and a stabil working position away from any bystanders.
Nick
/ blade on a string trimmer #10
Same here. I have two string trimmers with factory blade options. One is the 3-point and the other is circular with 8 cutting edges. The circular one will not do much moved up and down. The 3-pointed one does as he says. The circular one works great within about an inch of the ground. The higher it gets, the less effective it is.
Bruce
/ blade on a string trimmer #11
String trimmers designed for steel blade use are about as safe as any other machine using a steel blade, i.e. skil saw, table saw band saw, chain saw or even a hand saw. Keep guards in place and obey the safety rules and they work fine for heavy stuff like briars, small saplings etc that string trimmers wont cut. I also use the gator blades in steel (not the white plastic) and they work pretty good but not as well as the multi-tooth saw blades. Keep them away from wire, rocks and dirt and metal fence post and they stay sharp a long time.
/ blade on a string trimmer #12
The trick when running the three bladed one is to flip it over when it starts to act dull. You have a sharp side ready to go.
2020 International HX620 Quint Dump (A62613)
2020 International...
SKID STEER FORKS (A62613)
SKID STEER FORKS...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
Trimble Automated Steering GPS system (A64126)
Trimble Automated...
CONEX BOX (A65643)
CONEX BOX (A65643)
120 Gallon Tank (A64127)
120 Gallon Tank...
