2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,528
Nice looking garden in the back of that picture, too.
Just for the sake of discussion while I'm waiting for the sun to come up so I can get started, how long would you all think landscape timbers would last for my application? I would expect that if I built my arbors or trellises or whatever they're called (does anyone have a more appropriate word than arbor, cause I can't think of one) out of untreated pine 2x4's that it would last at least 10 years before it rotted to the point of falling apart. I am guessing that my landscape timber model will last 20-30 years before it gets to the point that it has to be replaced. If I built it out of pressure treated 4x4's and 2x4's I would expect it to last 40+ years. My grandpa's got a grape arbor at his house that has been around as long as I can remember (I'm 31) and show's no signs of failing any time soon. I assume he built it out of pressure treated lumber.
So anyway, I believe that my landscape timber model will last as long as I want it to; meaning that I'll want them moved, modified, or removed before it fails due to rot.
And whatever the group consensus is, we should have a good baseline test started after today! Check back in 20 years for results!
Come on over to western Oregon, you can have all the blackberries you want. You would have to look a long time to find someone who wouldn't be happy to let you take them all. They are kind of like the kudzu of the northwest.
...I am guessing that my landscape timber model will last 20-30 years before it gets to the point that it has to be replaced. If I built it out of pressure treated 4x4's and 2x4's I would expect it to last 40+ years...
We are also looking at planting several rows of blackberries. What variety did you plant? Do they have a good flavor...sweet or tart?
Your 20 gallons was harvested off of how long a row...10'...20'...?
Thanks!
David
I believe they are Quachita. They are very sweet. I have two rows 30 ft. long
I'm planning to put up some blackberry and grape 'arbors' (I think that's the word I want) this spring. I'm planning to get some 8' landscape timbers for this project. I'm hoping to use one at each corner for a post to make an 8x5.5 (I want it just wide enough to run my lawn tractor through to mow) rectangle. Then I'm going to rip some timbers in half lengthwise to make a frame around the top. Finally I'm going to tack some woven wire fencing with maybe 4x4 squares along the 8' sides and over the top.
I'm planning 2 of these structures, 1 for grapes and 1 for blackberries. Anyone see any reason(s) why this wouldn't work?
My main question is about planting the fruit. I believe I can go over to my FIL's and take some cuttings from his blackberry bushes, plant those, and they will grow into bushes at my place. I think I've heard that this works with blackberries. Can anyone confirm or deny?
What about grapes? My FIL has them too, can I take cuttings from them in the same manner as with blackberries?
Any other considerations?
You do mean Ouachita instead of Quachita, don't you?
I just wanted to share some blue berry tips that a commerical gower gave me.
1. no more then six cains out from the center plant, if there are more the blueberry quality and quanity suffer.
2. he uses as fertilizer double ground hardwood mulch. he puts in on in the spring and thats it. it keeps the weeds down and breaks down into a great source of food for the blueberrys.
enjoy.
