Black Smoke at start up and under load
   / Black Smoke at start up and under load #1
chliansh
Just bought a JD 4010 with 250 hours and I notice it has a puff of black smoke at start up. Sometimes I also notice a tad more under a heavy engine load. How much if any is normal?
   / Black Smoke at start up and under load #2
My tractor does the same thing and it's considered normal.
We haven't crossed paths before so let me welcome you to TBN!
Brian
Thanks and hello
I thought it was normal but have found some post that scared me a bit. I also see a bit of light black soot on the body panels by the exhaust.
   / Black Smoke at start up and under load #4
</font><font color="blue" class="small">( I also see a bit of light black soot on the body panels by the exhaust. )</font>
If your exhaust points towards (or near) a panel, that's normal also. I replaced my stub exhaust for a vertical pipe since it was blowing the exhaust on my loader arms making it black but what was worse is that it deflected the exhaust back in my face.
   / Black Smoke at start up and under load #5
Good Q. I bought a 4100 w/ 1080 hours and likewise there is a good sized "puff" of black smoke on startup, and certainly if I put a load on, there is some smoke. My understanding, under load, is that the fuel mixture is a bit rich for a moment and thus the black smoke. Are there any other symptoms of engine problems? I think that is what we are both asking. On warm days, 70+, it fires right up, so I'm taking that to mean the compression is good. Also, my understanding of these 3 cy Yanmar engines is they can run 2000+ hours easily. Any recommendations to get the most hours from them? Is 4000 hours reachable? Should I use fuel additive? Just looking for ways to max the live of this 4100. Thanks
   / Black Smoke at start up and under load #6
</font><font color="blue" class="small">( Are there any other symptoms of engine problems? I think that is what we are both asking.)</font>
CT - First, don't consider the black smoke a problem as it's normal on start-up and under heavy load. To discuss any other potential symptoms/issues, the number is probably too many to list but most are infrequent or rare. You could look through some other posts/threads to see what others have encountered. If you haven't already done so, do a search for 4100 for specific model information.
</font><font color="blue" class="small">( Also, my understanding of these 3 cy Yanmar engines is they can run 2000+ hours easily. Any recommendations to get the most hours from them? Is 4000 hours reachable? Should I use fuel additive? Just looking for ways to max the live of this 4100. Thanks )</font>
I would say that you could easily expect 2000 hours and probably closer to 4000 hours if you utilize appropriate preventative and scheduled maintenance. Although my JD isn't the 4100, I just do the tasks as defined in the owners manual and perform routine inspections looking at any potential issues.
For fuel additives, oil... check out the posts in the "Oil, Fuel and Lubricants" section of the forum.
Brian
thanks,
It stopped smoking now....... as it is broke /forums/images/graemlins/confused.gif
I started another thread about that problem.
Back to the smoke, I assume its mainy just a hint to back off, you are pushing it to hard. If you operate it for extended time with lots of smoke I assume you would just get carbon build up?
   / Black Smoke at start up and under load #8
</font><font color="blue" class="small">( It stopped smoking now....... as it is broke /forums/images/graemlins/confused.gif
Back to the smoke, I assume its mainy just a hint to back off, you are pushing it to hard. If you operate it for extended time with lots of smoke I assume you would just get carbon build up? )</font>
First, sorry to hear about your hyd issue. Mine is gear so I can't help you there.
Re. the black smoke I'm not a diesel mechanic so I don't know the specifics. Just everything I've seen and heard says it's normal. Watch a loaded semi climb a hill if you want to see lots of black smoke.
   / Black Smoke at start up and under load #9
I chipped my new 05 F-250 and when I crank it up it puff's one puff of black smoke or when I get on the gas hard it pour's black smoke out, thats just normal its a diesel burning fuel /forums/images/graemlins/grin.gif
   / Black Smoke at start up and under load #10
</font><font color="blue" class="small">( I chipped my new 05 F-250 and when I crank it up it puff's one puff of black smoke or when I get on the gas hard it pour's black smoke out, thats just normal its a diesel burning fuel /forums/images/graemlins/grin.gif )</font>
Actually, the black smoke is caused by not burning fuel. The soot is carbon, the result of an incomplete burn. That said, a little smoke is normal for a diesel, and alot of smoke, as brandon07 pointed out, can be a lot of fun in a truck (if it is made on purpose). White or grey smoke is generally a sign of a problem
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2022 LMC H40024 LOT NUMBER 206 (A53084)
2022 LMC H40024...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
New/Unused CFG Industrial QK16R Mini Excavator (A51573)
New/Unused CFG...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2012 International 4300 Reefer Truck (A53472)
2012 International...
