Loader BL-20 FEL Float Position
/ BL-20 FEL Float Position #1
JDEO
Williamsburg, IA
Branson 3820
I was thinking about winter snow removal and am wondering if my BL-20 FEL has a float position. When I was on it last weekend pushing the stick forward it only proceeded to lift the front of the tractor. is there no float position or didn't I push it far enough. I think it was on a hard stop when forward.
thoughts?
Thanks in advance!
Jeff
/ BL-20 FEL Float Position #2
My 4520R has a float position all the way forward but it takes a pretty good push to get it engaged.
/ BL-20 FEL Float Position #3
Same for me. It's a very firm detent. After some use it has loosened up a bit. This is with the fender mounted joystick that operated the valve by cable.
/ BL-20 FEL Float Position #4
You have it, probably just stiff as stated above-lube on the linkages can help too.
Practice with the loader about 4' in the air to prevent doing wheelies :)
I will try again tonight... FYI my FEL has the controller forward on the mount frame not the fender if that makes a difference.
/ BL-20 FEL Float Position #6
You should be able to feel the detent without the tractor running.
So last night without the tractor running I had no detent when pushing forward but there was when pulling back. is this correct? or is the valve upside down? hydraulics plumbed backwards? I know as it currently is setup, forward is down pulling back is up; left and right for bucket curl.
also when pulling back I could feel the detent but it would always return past the detent not stay like I would expect it to.
/ BL-20 FEL Float Position #8
Some valves have a spring loaded over travel rather than a hard stop. That may be what you are feeling.
The float detent should be there, but it may be quite firm. On mine I thought it wasn't there and asked the dealer about it. His advice was don't baby it, it's there. YMMV
/ BL-20 FEL Float Position #9
How old is your tractor? Mine was quite hard to get into the float position when it was new but has softened up fairly quickly (or maybe I just learned to be more aggressive) It should stay in the float position by itself until you pull it back
So I finally found the valve manual on line. The valve is mounted 90 degree off but plumbed normally. The detent is actually to the right past the dump curl. Pulling back on the stick gives a rapid dump curl at the top of the raise.
Odd but it seemed to work correctly tonight.
/ BL-20 FEL Float Position #11
I bent two sets cable ends forcing mine into the float position. (Both covered by warranty) have given up on using because of the amount of force it was taking.
/ BL-20 FEL Float Position #12
I have an 8050, I have used the float position a few times it was hard to get it to the float mode. A couple of weeks ago I was working in the driveway and went into float and all of a sudden my joy stick was flopping around and feeling vague got back to the shop and started to check it out the wobble stick block was split in half, I have it c clamped now so as to be able to use the loader my dealer has the part on back order unknown delivery,,,, slow boat from Korea maybe..
/ BL-20 FEL Float Position #13
If on hard surface fine. If on dirt have to be really watchful of bucket tilt. Little tell tale really helps on this.
On digging in a pile of something, again have to watch tilt. Mine works best with the blade flat and then when the bucket fills to the point where the tires want to spin out, pop it back into regular mode and roll the bucket back toward you slightly as you ease the tractor back slightly to finish filling the bucket.
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
HOMEMADE 52"X12' S/A TRAILER (A62130)
HOMEMADE 52"X12'...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
