BL 150 loader loader control lever frozen
   / BL 150 loader loader control lever frozen #1
Hammah17
TYM 2515H
I have a TYM 2515H with a BL 150 loader, tractor has 21 hours. Scooped some dirt, dumped it went for the next scoop and now the control lever is frozen. Bucket will curl and dump but the loader will not raise or lower.
   / BL 150 loader loader control lever frozen #2
So how do you have a tractor with 21 hours that's out of warranty? You should be making your case there, not here.
   / BL 150 loader loader control lever frozen #3
I agree with Harry but I would still apply some PBlaster to the joy stick linkage. I suspect it's devoid of any lubricant and locked up.
   / BL 150 loader loader control lever frozen #4
Do you mean the joystick won’t move or the joystick moves but loader does not?
If joystick moves I would suspect one of the quick disconnects for raise lower is partially connected. You will most likely have to support the weight of the loader to reconnect those but you could first try putting loader in float to see if it might slowly drift down. Doubtful but possible.
   / BL 150 loader loader control lever frozen #5
So, is the loader full down? Sometimes, getting them back out of float takes a really serious hard jerk.
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2014 Nissan Sentra Sedan (A56859)
2014 Nissan Sentra...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
2019 Hitachi ZX300LC Hydraulic Excavator (A56857)
2019 Hitachi...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
1999 CAT 350E2 Haul Truck (A55272)
1999 CAT 350E2...
