Bill Craig owner of 1997 770 John Deere
   / Bill Craig owner of 1997 770 John Deere #1
WmRCraig
central part of North Carolina near Raleigh
1997 770 John Deere
Retired Facilities Engineer that likes to operate my tractor on my small farm located in central North Carolina. Now my tractor is giving me a fit. TRACTOR RUN GOOD FOR AN HOUR THEN ACTS LIKE IT IS RUNNING OUT OF FUEL, I HAVE REPLACED THE FUEL FILTER, DRAINED THE TANK, PUT IN NEW FUEL, CLEARED THE LINES FROM TANK TO FILTER SYSTEM. IT RAN GOOD FOR ABOUT ANOTHER HOUR THE STARTED TO SLOW DOWN AGAIN, FINALLY GOING DEAD. IF I LET IT SET FOR A LITTLE WHILE IT WILL CRANK AND RUN FINE FOR ANOTHER HOUR... HAS ANYONE ELSE HAD THIS PROBLEM?
   / Bill Craig owner of 1997 770 John Deere #2
Bill, welcome to the forum!!! I had something similar with one of my Kubota's. Turned out to be junk in the fuel tank that would occasionally block the output hole. On mine the fuel filter holder is clear and I could see it run out of fuel at the filter. It had to be before that point. Blew out the fuel line, drained that tank and added some sea foam cleaner. That seems to have worked.
Now if you are not running out of fuel at the filter it starts sounding like an injection pump issue. I sure hope not, they can get pricey.
Post your question in the John Deere forum where more owners of 770's hang out.
MarkV
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
UNUSED RAYTREE RHBC72-72" BRUSH CUTTER (A51248)
UNUSED RAYTREE...
2012 WABASH 53x102 DRY VAN (A53426)
2012 WABASH 53x102...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
