BIG TEX DECK REPLACEMENT
/ BIG TEX DECK REPLACEMENT #11
Ditto what the others said about the bolts and boards. I wasn't thrilled with drilling all new holes thru my support webbing every time i redeck.. so what I did was cawled under the trailer and used a drill with small pilot bit and brille dup thru the old holes.. then on top.. hogged the holes out with proper bit and put the torx head self-tapper bolts back in.
soundguy
Thanks Soundguy. Maybe I'll bring it to Florida when I visit my brother in law. I'm thinking it would be easy just to watch you do it. Just kidding.
/ BIG TEX DECK REPLACEMENT #13
Speaking of that.. i redecked mine in 2001 or so.. and I bet it's gonna need a new deck next year.. I got one board with a crack in it near the front so far..... luckilly the crack is over a support so no issues yet..
soundguy
/ BIG TEX DECK REPLACEMENT #14
I re-decked mine because my Dumb-*** brother in law borrowed my trailer and set the deck on fire.
He paid for the wood but still...
Some people.
/ BIG TEX DECK REPLACEMENT #15
I replaced the deck on a 16 foot trailer I had as follows.
Drilled three holes in the two cross members on the trailer and bolted 2X6 pt to the cross members. Then, used regular deck screws to fasten the deck to the 2X6 since their only purpose was to hold the deck boards down. A lot easier than trying to screw the new deck into the metal.
/ BIG TEX DECK REPLACEMENT #17
Great Thread!
I stepped through the deck at the end of the summer.
What wood should I use?
I have been told hemlock, tamarack or PT.
Is the $ for PT really worth it? My trailer sits in the open year round.
Thx
/ BIG TEX DECK REPLACEMENT #18
My deck came as non pt wood.. it lasted 1yr in florida.. the pt wood I put on has made it 7 so far..
soundguy
/ BIG TEX DECK REPLACEMENT #19
Old carpenter's trick is to cut the wood around the screw or bolt with a hole saw and then cut it off with a sawzall.
I think many trailers have a weak point at the rear anyway. On mine, I cut off the rear rail, replace the wood, and then go back with a larger piece of angle.
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2014 Audi Q7 AWD SUV (A59231)
2014 Audi Q7 AWD...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
FLARE STAND (A60736)
