BH Hydro Lines
/ BH Hydro Lines #1
craigw
Sacramento, CA
CK20 HST
All,
When my BH is attached, the Hydro lines that run along the BH frame and connect to the hydro valve next to the brake pedal. When I turn my front wheels all the way to the right, the front right wheel rubs on the hydro line closest to the tire. I cannot see how to adjust that valve away from the tire any more that it is. Has anyone else had this problem? I am concerned that one day I will forget about not turning so tight and either break the hose or worse the valve. What would you suggest?
Thanks,
Craig
/ BH Hydro Lines #2
I would suggest that you have the dealer that installed the backhoe fix the problem. Probably will need to change the fitting to an angle so that the hose hangs out of the way of the tire.
There's no way it should be doing this.
Can you take a picture of the problem area, or pics?
John
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2017 TAKEUCHI TL8 SKID STEER (A65056)
2017 TAKEUCHI TL8...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A68842)
TWO PALLETS OF HYD...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
2007 Ford F-350 XL Lariat (A64911)
2007 Ford F-350 XL...
