BH Hydro Lines
/ BH Hydro Lines #1
craigw
Sacramento, CA
CK20 HST
All,
When my BH is attached, the Hydro lines that run along the BH frame and connect to the hydro valve next to the brake pedal. When I turn my front wheels all the way to the right, the front right wheel rubs on the hydro line closest to the tire. I cannot see how to adjust that valve away from the tire any more that it is. Has anyone else had this problem? I am concerned that one day I will forget about not turning so tight and either break the hose or worse the valve. What would you suggest?
Thanks,
Craig
/ BH Hydro Lines #2
I would suggest that you have the dealer that installed the backhoe fix the problem. Probably will need to change the fitting to an angle so that the hose hangs out of the way of the tire.
There's no way it should be doing this.
Can you take a picture of the problem area, or pics?
John
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
Vibratory Plate Compactor (A64553)
Vibratory Plate...
PORTA POTTY (A68842)
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A67714)
2015 VANTAGE...
2012 PUMA BUMPER PULL (A67714)
2012 PUMA BUMPER...
2012 BRENNER TANK PUP TRAILER (A67714)
2012 BRENNER TANK...
