craigw
All,
When my BH is attached, the Hydro lines that run along the BH frame and connect to the hydro valve next to the brake pedal. When I turn my front wheels all the way to the right, the front right wheel rubs on the hydro line closest to the tire. I cannot see how to adjust that valve away from the tire any more that it is. Has anyone else had this problem? I am concerned that one day I will forget about not turning so tight and either break the hose or worse the valve. What would you suggest?
Thanks,
Craig
Thanks,
Craig
