Bevel prep for T joint?
/ Bevel prep for T joint?
Mocked up the slide assembly. Once I had it set up, I then tack welded the pieces so the couldn稚 shift as I was drilling them. Each assembly was about 3 thick and was held together with (4) 1/2 grade 8 bolts.
Finished photos after a day of hard use.
/ Bevel prep for T joint? #24
Looks like you got it. I can't wait to get out and split some wood. !!
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2020 DRAGON ESP...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
