Bevel prep for T joint?
/ Bevel prep for T joint?
Mocked up the slide assembly. Once I had it set up, I then tack welded the pieces so the couldn稚 shift as I was drilling them. Each assembly was about 3 thick and was held together with (4) 1/2 grade 8 bolts.
Finished photos after a day of hard use.
/ Bevel prep for T joint? #24
Looks like you got it. I can't wait to get out and split some wood. !!
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
2022 EZ-GO ELITE...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2017 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
