Better lighting for kitchen in log cabin
/ Better lighting for kitchen in log cabin #1
stl
Missouri
JD 2305 - sold
We just finished building a log home (we didn't, builder did), and with a porch and small windows and lots of kitchen cabinets, ended up with a very dark kitchen.
Would using flourescent shop lights above the cabinets (pointing upwards) work?
Too much heat?
I put up 3 strings of rope lighting, but it is still a bit dim.
Other ideas?
/ Better lighting for kitchen in log cabin #2
Would using florescent shop lights above the cabinets (pointing upwards) work?
Too much heat?
It will work just fine provided there's adequate space between the cab tops and the ceiling for the light to 'escape' and fill the room
The other trick is to use under cabinet task lighting. There are LED systems that install quickly. Stay away from under cab halogen (gets way too hot) or florescent (bulbs are very $pendy)
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2021 OTHER GULF STREAM VISTA CRUISER (A59909)
2021 OTHER GULF...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
8041 (A61165)
8041 (A61165)
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
(APPROX.14) CHAIRS (A62131)
(APPROX.14) CHAIRS...
