Better lighting for kitchen in log cabin
/ Better lighting for kitchen in log cabin #1
stl
Member
Missouri
JD 2305 - sold
We just finished building a log home (we didn't, builder did), and with a porch and small windows and lots of kitchen cabinets, ended up with a very dark kitchen.
Would using flourescent shop lights above the cabinets (pointing upwards) work?
Too much heat?
I put up 3 strings of rope lighting, but it is still a bit dim.
Other ideas?
/ Better lighting for kitchen in log cabin #2
Would using florescent shop lights above the cabinets (pointing upwards) work?
Too much heat?
It will work just fine provided there's adequate space between the cab tops and the ceiling for the light to 'escape' and fill the room
The other trick is to use under cabinet task lighting. There are LED systems that install quickly. Stay away from under cab halogen (gets way too hot) or florescent (bulbs are very $pendy)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2017 Nissan Pathfinder SUV (A61569)
2017 Nissan...
2011 Ram 1500 Pickup Truck (A61568)
2011 Ram 1500...
2006 Ford E-350 Enclosed Service Van (A61568)
2006 Ford E-350...
