betstco flail mower
   / betstco flail mower #1
sixer
ck 25 hst kioti
Hello all ;
New to this forum stuff so I'll just get it out there. Picked up a betstco flail mower price was right so I thought. Anyway have had issues with it tilling on soft ground, like rear roller is plowing. Roller is free and no binding, front of mower is 2 degrees nose up. My thought is that the rear roller is to small it has a 4 inch diameter where most companies are running 5.25 to 6 inch diameter rear rollers the mower is 72 inches wide and weight is around 580 pounds. Has anyone had this kind of issue. Am I on the right path. Any help would be appreciated. making a new rear roller is possible just looking for input.
THANKS
sixer
   / betstco flail mower #2
adjust the front up until you're sure the cutters are off the ground at least an inch or 2.
and welcome to the forum.
The cutters are off the ground by 3 inches at least until I hit sandy soil then it plows.
Thanks
   / betstco flail mower #5
DO NOT pay any atttention to the rear roller diameter;
If the tires on the mule are at the required air pressure:
1. Lower the rear roller one position.
2. level the flail mower with the top link using a torpedo level by using the gearbox cover if it is flat as a reference point
3. mow
"Welcome to the Flail Mower Nations"
   / betstco flail mower #6
Hello all ;
THANKS
sixer
I assume that you bought their EFGC model flail mower which is 4" diameter roller. Actually it is made by 108 mm diameter steel pipe. Watch out those small bolts on the roller end, it is easy to fall out.
I suggest you:
1. Lift up the skid. Flail mower should be supported by its roller when mowing, only if you don't mind the skids make two deep track on the ground.
2. Adjust roller's position, it has nearly 2 inches height adjustment capacity.
3. Adjust your tractor's 3 point hitch upper link length, make the mower is parallel with the ground, and the hammer could cut the grass but not the ground.
   / betstco flail mower #7
I suggest you:
72" width and 580lbs i'm guessing he bought the light duty flail. i just purchased their 'heavy duty' model at 48" wide its supposed to weigh in at 600lbs.
the 2 lighter models have really light flails too, not sure how much that will affect things but i went with the model i did because the flails are 27oz and the price differance really isn't much. fwiw
my mower is scheduled to show up tomorrow. i really hope its everything i want it to be... we'll see
   / betstco flail mower #8
I suggest you:
Hey Jack, I haven't seen a post from you in a long time. I hope everything is going good.
   / betstco flail mower #9
Hi, I m fine, the business is going very well, especially in western Europe market. The US-China trade war will hurt my business in USA, thanks to our stupid Chinese King Mr Xi, we all have to pay more for his wrong policy.
I think this year I come to TBN every week, much more often than years ago. I visited Texas this year, then sunshine and steak is impressive and very good.
   / betstco flail mower #10
Good to hear. I think our presidents are both playing high stakes poker. I hope things even out. Give and take. Ying and Yang.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
JOHN DEERE 54D LOT NUMBER 162 (A53084)
JOHN DEERE 54D LOT...
