Best way to route/trench water with an ATV?
   / Best way to route/trench water with an ATV? #11
Or you could just scrape the heal of your boot along. This avoids the obvious second redundant tire trench.
   / Best way to route/trench water with an ATV? #12
If you have a neighbor with a tractor and plow, just have him cut a furrow down where you want it. Of course do it while not getting stuck. A 1 bottom plow would be ideal but anything more that that will still leave one open furrow.
I've done this in my former pond (turned into horse pasture) for several years. It was swampy where the water "meandered" through, now my tire tracks have turned it into a channel/stream and one can walk up to the edge of channel and jump over it instead of sinking in mud within 20'.
Downstream (and actually on neighbors land) I did the same thing. He was building ATV trails so I "helped him" (as it helps me drain my land) and cleared all the brush from the stream/marsh bed. Just having 6" deep ruts really helps keep the water flowing. My city-slicker brother-in-law came to visit and wanted to ride the ATV so I sent him to "clear the channel", cause it's the muddiest place and most fun. He did a good job. Totally trashed (in mud) my 4 wheeler. But turned off "the stream" track too early and now water is going where it forms a marsh area. No problem to fix come this spring.
Here's first time driving through. The "channel" area starts around 0:40 secs. Channel is a lot more defined now after multiple trips.
First ride through - YouTube
I thought about buying an old "horse drawn" plow and towing it behind the 4 wheeler, or using my logging winch to pull it from 165' away through the marsh. Like you said, some of these places you can barely walk through without it sucking the boots off your feet, and can't drive through (except ATV). But so far just making tracks works
Me and you are in very similar situations. I thought about that plow idea as well.
The way I see it ... this whole thing has to happen in phases. Getting any type of machine there now is a no go which is why the ATV is one of the only options.
The tire rut .. or a similar type trench with some tool seems like the required baby step #1 to at least control hopefully most of the water and let the rest of the land dry up.
Step 2 seems like when the land is dried up, you can do more official fixes with heavier machinery if needed.
   / Best way to route/trench water with an ATV? #14
A tire rut is a trench? Am I missing something.
That ripper on an ATV, is a video I would love to watch. Then, see a copy of the repair bill for the ATV.
Agree. For the price of any tool you would need on the ATV to provide a long term solution, just rent a mini ex and do it right.
   / Best way to route/trench water with an ATV? #15
Well, excavators can go some amazing places too; and if it's too much for them they can just change the landscape by either draining down or building up. Pricey though.
Yes. I'll waiting for a "dry year" or like you said, when the surrounding area has been made more drier by the trench, to then get the tractor and brush mower in there.
...but I'm also thinking that I might be able to get in there with a tractor and brush hog once the ground is frozen; if there's not too much snow. That is, if there's not too much snow for the mower to cut low enough. I realize most people in upstate NY don't mow in January, but make hay when sun is shining, err...the snow is flying....whatever.....
It'll be interesting to see exactly when and how much of the ground around the channel freezes compared to the surrounding area.
   / Best way to route/trench water with an ATV? #16
Hey guys i have water on my property and I also have the beginnings of a creek. It want's to be a full creek that connects into a large creek, it's just obstructed. This spring I plan on unobstructing certain parts manually. The second part is that I have to route water from the sources to this creek as they follow no pattern right now.
All I really need to to is dig out a rough path for the water to go (for reference water has been following just my quad tracks quite well). I was thinking of using a tool like this to put on the quad and maybe tear a line to where i want the water to go https://www.amazon.com/Titan-Attachments-Hitch-Mounted-Ripper/dp/B074MJBD7R/ref=asc_df_B074MJBD7R/
It would be great to hear others thoughts on possible solutions.
If it's like you say and how you want to do it, I would use that thing in a heart beat.
The good part is that you're not limited to an ATV: you could use a UTV, small tractor, small truck, almost anything that will get back there.
Good luck!
We bought a tow behind flail mower from China to mow this area. The water level varies .. but you can tell even the parts we mowed allowed for the flow of water to go there vs the higher sections.
Good luck!
For sure thank you! .. Going to try the tire method first and see what happens.
   / Best way to route/trench water with an ATV? #18
In this particular order...
Go to Craigslist, sell your ATV
Go to Craigslist, buy a Ditchwitch
Do your trenching
Go to Craigslist, sell your Ditchwitch
Go to Craigslist, buy an ATV:D
   / Best way to route/trench water with an ATV? #19
Don't underestimate the footprint of an excavator. They may be heavier, but the track spreads the weight out over a larger area. I have gotten my ATV stuck- bad- in a spot where the lag tracks of a 20 ton machine walked right over.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
