Best way to route/trench water with an ATV?
   / Best way to route/trench water with an ATV? #1
boostmg
Pennsylvania
Branson 3620 TLB Hydro
Hey guys i have water on my property and I also have the beginnings of a creek. It want's to be a full creek that connects into a large creek, it's just obstructed. This spring I plan on unobstructing certain parts manually. The second part is that I have to route water from the sources to this creek as they follow no pattern right now.
All I really need to to is dig out a rough path for the water to go (for reference water has been following just my quad tracks quite well). I was thinking of using a tool like this to put on the quad and maybe tear a line to where i want the water to go https://www.amazon.com/Titan-Attachments-Hitch-Mounted-Ripper/dp/B074MJBD7R/ref=asc_df_B074MJBD7R/
It would be great to hear others thoughts on possible solutions.
   / Best way to route/trench water with an ATV? #2
Not sure an ATV would have the weight/traction/power to be very effective.
I would probably rent a mini excavator for a day.
To start I don't think I need any major depth ... I would try to take like 2-3 inches off the top .. and maybe 3-6 inches wide ... and that should do the trick to let the water erode the rest away.
I could also be totally wrong. But that was going to be my first attempt
Edit: Also it's really wet... which I forgot to mention .. so it's hard for anything to get in there besides and ATV
   / Best way to route/trench water with an ATV? #4
I've opened up trenches/creeks (streams) with my ATV. (i.e. turned swamp land into a flowing creek.)
Never used an attachment.
I just cut the brush so that I could drive with one tire right in the steam bed. Doing this repeatedly, especially in the muddy season soon establishes a trail and ruts. Once the water is flowing in the ruts it does a good job of keeping itself a channel.
That's exactly what I have to do!!!!!!
How long have you had it this way? What has happened to the "ruts" you made over time?
Right now I am just realizing how to fix this issue .. so I have some ruts already made but they aren't going where I want. So the plan as I mentioned above is step #1, create a free flowing stream by unobstructing roadblocks .... then step #2 just divert the water with my ruts into the stream.
   / Best way to route/trench water with an ATV? #6
I've done a lot of trenching drainage ditches with my mini backhoe. I found the best way was to pay attention to the slope of the drainage ditch, always making sure that the drainage ditch was dropping as it went along - to keep the water flowing. This was important where it cut into other ditches. I'd figure my low points and high points and decide how much I needed to drop. If I dug too deep, I had a wet pocket. If I dug too little I had an obstruction and a wet pocket above that.
I used a David White level like this one. (I used it for building as well.) zzzzzzzzzzzzzzzzzzzzzzCapture.JPG
David White L6-2 22X Power Optical Meridian Level - 44-D8824 - EngineerSupply
   / Best way to route/trench water with an ATV? #7
I would get in there with a cutter mattock and do it by hand.
   / Best way to route/trench water with an ATV? #8
I've done this in my former pond (turned into horse pasture) for several years. It was swampy where the water "meandered" through, now my tire tracks have turned it into a channel/stream and one can walk up to the edge of channel and jump over it instead of sinking in mud within 20'.
Downstream (and actually on neighbors land) I did the same thing. He was building ATV trails so I "helped him" (as it helps me drain my land) and cleared all the brush from the stream/marsh bed. Just having 6" deep ruts really helps keep the water flowing. My city-slicker brother-in-law came to visit and wanted to ride the ATV so I sent him to "clear the channel", cause it's the muddiest place and most fun. He did a good job. Totally trashed (in mud) my 4 wheeler. But turned off "the stream" track too early and now water is going where it forms a marsh area. No problem to fix come this spring.
Here's first time driving through. The "channel" area starts around 0:40 secs. Channel is a lot more defined now after multiple trips.
First ride through - YouTube
I thought about buying an old "horse drawn" plow and towing it behind the 4 wheeler, or using my logging winch to pull it from 165' away through the marsh. Like you said, some of these places you can barely walk through without it sucking the boots off your feet, and can't drive through (except ATV). But so far just making tracks works
   / Best way to route/trench water with an ATV? #9
A tire rut is a trench? Am I missing something.
That ripper on an ATV, is a video I would love to watch. Then, see a copy of the repair bill for the ATV.
   / Best way to route/trench water with an ATV? #10
Ehhh...if it's in the right spot....and works...it is!
(....or spend the $100-$200 per hour (and drop off/pick up min. fees, etc..) for an excavator...)
Sometimes tire ruts get ALOT deeper than the 2"-3" channel the OP wants.
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2025 LandHonor LHR-CIA200 200lb Cast Iron Anvil (A49461)
2025 LandHonor...
2007 Reitnouer 40 Ton T/A Flatbed Trailer (A49461)
2007 Reitnouer 40...
2021 New Holland C327 Compact Track Loader (A51039)
2021 New Holland...
