Best Way to Provide DC to Sprayer?
   / Best Way to Provide DC to Sprayer? #21
Very handy connectors.
   / Best Way to Provide DC to Sprayer? #22
I would wire some Anderson Power Pole connectors on a relay to the back of the tractor …
I have these on all my tractors wired to the battery to power my 20gpm diesel pump BUT they get loose after few years
   / Best Way to Provide DC to Sprayer? #23
Just getting replacement connector housings. The spring that holds contact wears out.
   / Best Way to Provide DC to Sprayer? #24
All my rolling stock has this type connector and any thing needing 12v power has the same connector.
I keep couple of 10' & a 15' ext cord. Makes everything work anywhere,
Sprayer, fuel pump, small spreader, big Sprayer shutoff, planter power, etc.
   / Best Way to Provide DC to Sprayer? #25
Ordinarily, I use an EZGO, but using a sprayer is not good for the paint.
What's the best way to get DC to the sprayer, maybe 15 feet from the tractor's battery?
Well, maybe 15' feet of wire?:p
In light of the highlighted text in the OP's post, one wonders if the OP is as concerned for what it does to the operator and other things, breathing and not in the environment around and beyond, say, the intended target(s).:oops:
   / Best Way to Provide DC to Sprayer? #26
Is that an Amazon item? Since some things have odd names, what do you call it?
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
44052 (A55852)
44052 (A55852)
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
XCMG CV83PD (A53317)
2012 International WorkStar 7300 4x4 Altec AA755MH 55ft. Material Handling Bucket Truck (A55973)
2012 International...
