Best way to cut cast iron?????
   / Best way to cut cast iron????? #11
My $700 PP60 will cut that no problem. I've cut thicker metal.
   / Best way to cut cast iron????? #13
Would it be easier and cheaper to get a smaller brake drum? Drum forges are a pain. You can't heat a long piece of metal in the middle. I would use the drum as a firepot and set it into a tray of some sort. An overturned oil drum works good.
A cranked stick welder blows through cast iron faster than *&^*. As long as you don't mind the mess
I am planning to drill and tap the cut edge and bolt it to the under side of a metal table so i have some room around my forge for extra coal, tongs ect, so a smooth cut is important. Thanks again Ed
Tried to cut it with the 4" cutting wheels, used 8 and not half way through the thing, and it is only a little over 1/2" thick where I am cutting it. Local machine shop has a band saw that they say will cut it and for only $15, wish I had not tried to save money and called them first. Thanks guys.
UNUSED IRANCH 8" MINI EXCAVATOR BUCKET (A57193)
UNUSED IRANCH 8"...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A53422)
2018 Chevrolet...
Deere 410L (A53317)
Deere 410L (A53317)
2007 CATERPILLAR D5G XL CRAWLER DOZER (A52707)
2007 CATERPILLAR...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
