Best way to clear unwanted trees from pasture
   / Best way to clear unwanted trees from pasture #241
One of these may still be the best option for stump, root removal and initial cultivation.
[video]https://www.google.ca/url?sa=i&url=https%3A%2F%2Fwww.pinterest.com%2Fpin%2F720716 746598095164%2F&psig=AOvVaw2sf91SgM3DPt6XpUCG1EhU&ust=1581514618248000&source=images&cd=vfe&ved=0CAIQjRxqFwoTCLiAz6rPyecCFQAAAAAdAAAAABAE[/video]
   / Best way to clear unwanted trees from pasture #242
What kind of a root system and soil ? Is pulling the tree out by practical ? If cut flush and the stump sprayed with herbicide. How long does it take for the root system to rot and allow conventional mouldboard ploughing ?
   / Best way to clear unwanted trees from pasture #243
WOW, just catching up on this, 6 mos later and still chipping away, hauling, loading/unloading, 150 hours of your time so far working just with the tractor alone, 3K in time for that @ 20/hr, 30K tractor? , 10K saw/grapple i think was what you were saying, plus fuel, plus wear/tear, plus herbicide, lost time for other projects, still have to coat stumps, still have to deal with holes/fixing due to rotted stumps ( per your comments ) WOW you are a glutton.
in a weeks time @appx 10K this could have been cleared, stumps removed, graded, ready to be disked/planted with seed of choice and growing 5 mos by now and you would have been on to next project.
to each his own but i have been down this road more than once and the first two times taught me to have someone else do it - i got my pride out of burning the piles and watching the new stuff grow in
you would have the house half done by now lol
   / Best way to clear unwanted trees from pasture #244
Pretty sure the tractor (and likely the grapple) would have been a sunk cost given the intended uses for the property (as originally described) and given seeding 35 acres would run pretty close to $2k (at 50lbs/acre) I'd question if hiring it out, and starting with bare earth would actually have been a cheaper option even if it'd have been faster (depending on local backlogs). That's of course assuming the 10k is a valid estimate for the amount of work that needed to be done - which may or may not be valid for the OP's area.
I know in my area landscapers and clearing crews have gotten pretty ridiculously (by my standards) priced. For example: 2k-4k+ estimates for removal of shrubs and a couple dozen trees in the beds around a house -- all of which was removed by myself (with a tractor) and coworker (with a chainsaw), and mulched with a rented chipper in under 16 hours of work.
In fact it's bad enough, that if it wasn't for me actually enjoying my work (most of the time), and my disinclination to put up with the types of personalities that I know exist in the local area I'd be very tempted to walk away from my (reasonably well paying) engineering job and start a small clearing/landscaping/treecare outfit. It seems that (around here) anything fast will be excessively expensive, anything reasonably priced will likely take months (and lots of phone calls) to get done, and anything in-between will be expensive --and the price isn't always reflective of the quality of work.
All of which has driven me to the conclusion that in my current locality there's not much that I can't do faster, cheaper and of equal -or in some cases better- quality by either buying or renting the necessary equipment myself. Which I suspect is likely due to an excessive number of white-collar workers who can't/won't do such things themselves and are more than willing to pay whatever price to have someone else do it for them.
So as you said to each their own, and based upon what I've seen/heard around my part of the country I'd add each really needs to investigate the options/costs for their own area.
   / Best way to clear unwanted trees from pasture #245
You're right. Clearing 50 acres to plant would cost more here too. The price for having someone else do what you could do for yourself depends a lot on location. Around here, 10K wouldn't do more than get you started - if you can find someone to do it at all.
Quality work is a whole different subject.
None of this was true back where I grew up. But then that's part of why people leave there when young and return there to retire.
rScotty
   / Best way to clear unwanted trees from pasture #246
i had 15 acres of soft maples some in the 12 inch size for 10K took them 3.5 days - last year 5600 bucks, cleared, piled, disked - I had another 1.5 acres cleared for 400 bucks took less than 2.5 hours. He has a minimum charge.
disking is 15 to 20/acre here - if you are just talking pasture grass very cheap to broadcast and drag something over if you wish OR you can drill it, it costs 75 bucks to rent a drill here or 3pt broadcast seeder.
anyway............pretty cheap/easy to get it planted - I planted 15 acres of CRP and it ran 300/acre for seed alone last yr but that was for special warm season grasses and pollinator species
biggest advantage of course is time/effort, wear n tear, costs, at this point in life, id rather be done, have my grass, have the crap gone, have the field taken care of forever, no more maint/time other than mowing and letting the horses eat ;-)
i know for each his own but filling in holes for years and having bumps/lumps from the rotting roots and stumps or buying yet another piece of equipment then more time/effort to run it, that wears on me, then more time and energy and carrying all those loads of dirt around for the next rotting years if i choose not to remove stumps and trying to find/fix them and hope i dont break something is added stress on me and equipment.
nothing like putting time/effort/pride of ownership into your land and getting that experience but I quit some of that so i could spend more time w/family.
   / Best way to clear unwanted trees from pasture #247
He has 35 acres of pasture. If your 15 acres was $10K, then his would be $23K?
There is no way 15 acres could be cleared for $10K out here. I wish it could.
   / Best way to clear unwanted trees from pasture #248
i was guessing 15 to 20 acres tops on his , my 15 was solid growth his is very thin and wouldnt take hardly any time at all in a lot of it, kind of moot at this point for him just making observations for the next guy that takes on something like this - its frustrating cleaning up others messes and overgrowth. This kind of thing is a menace for pasture or unmanaged CRP.
a lot of it depends on trees/soil/size of overgrowth and the equipment the guy doing it has too regarding cost. Some of that root stuff can be pulled up with a trackhoe and some will come right up driving thru the trees with a ripper/chisel on a dozer if its smaller and that saves them time/wear on their machine doing stuff like that so costs are lower, just some things to think about when trying to figure out what to do
   / Best way to clear unwanted trees from pasture #249
Yes, all great info. Post#1 says 35 acres of pasture.
   / Best way to clear unwanted trees from pasture #250
yea it does but he provided aerials of it and that really gives a better perspective of the project - I feel for him, i have been thru this on multiple properties, only one my own that i purchased from my cousin who let things go.
I wore my self slick on this stuff, tore up things, wore things out including myself so i get it - i applaud his passion!!!!
DRAGON 500 BBL ACID TANK (A58216)
DRAGON 500 BBL...
UNUSED FUTURE 13" MINI GRAPPLE (A58376)
UNUSED FUTURE 13"...
UNUSED MOWERKING SSRC 72" HYD BRUSH CUTTER (A58376)
UNUSED MOWERKING...
2016 INTERNATIONAL 4300 SBA 4X2 FLAT TOP ROAD TRAC (A58375)
2016 INTERNATIONAL...
7019 (A59228)
7019 (A59228)
2012 International Prostar (A56438)
2012 International...
