Best way to clear small trees from pasture
   / Best way to clear small trees from pasture #11
Try a tree puller for your fel, I've got one by mtl and can usually pull up to 3 inch sweet gum trees using my l3901. Your tractor is bigger by a decent amount so 4 inch is likely to be doable for you.
   / Best way to clear small trees from pasture #12
Visit or call your state forestry office. Ask for a list of contractors who do mastication work. Get some bids and have it masticated. Then you can maintain with your tractor and cutter. This is a small job of 1-2 days work. Why tear up your equipment trying to rotary cut 20’+ trees?
   / Best way to clear small trees from pasture #13
I thin my pine stands - almost every year. 600 to 800 small pines - 1" to 6" on the base. Identify - fell - drag to piles - chip. By myself, it will take the better part of two months. The - "drag to piles" is the tough part. This year my son & his friend WILL help. All the trees are felled with a chainsaw. The remaining stumps will all rot out in five years.
The only trees I have are Ponderosa pines. So - I have no idea what a chipper would do to a tree with thorns. I tend to think - at least some of the thorns would probably make it thru my chipper without being busted up. You could use a chipper with a "sizing discharge screen" that would probably break up all the thorns.
Even with the most heavy duty bush hog - I would be very hesitant to try shredding those trees. It's going to be hard on all the equipment involved. If you care to see what it would be like - take a look at the videos on the Brown Ag web site. The trees are knocked down and shredded. But I doubt it would take care of any thorns.
   / Best way to clear small trees from pasture #14
My cutter is not robust enough to just mow them down as it is rated for only 1" stems. Actually, that surprised me and when I first started, I was probably mowing over 2" stems or even a little larger but I stopped that! I read the manual!
NEW Rotary Cutters cut everything at first. As the light blades dull a light cutter undergoes increasing stress.
25 horsepower will power a Light Duty 5' Rotary Mower
35 horsepower will power a Heavy Duty 5' Rotary Mower
35 horsepower will power a Light Duty 6' Rotary Mower
45 horsepower will power a Heavy Duty 6' Rotary Mower
Using a HD Rotary Cutter of 1,000 - 1,100 pounds you will need an FEL to hold down the front of the tractor on moderate slopes.
I use a Land Pride RCR2660 (60") HD Rotary Cutter with a Class 4 driveline, weighing 1,002 pounds. My 2013 vintage L3560 powers RCR2660 through Florida jungle mowing over flat land with no complaint and no damage/distortion to the implement. I "try" not to cut brush thicker than 1-1/2". $3,120.00 in May 2018.
I had a Land Pride RCF2060 (60") medium-duty Rotary Cuter with a Class 3 driveline, weighing 620 pounds, nominally rated for 2" brush. It required a ~~$600 repair each year when I would get into brush. It would have been reliable cutting grass. $1,600 in February 2014.
If you buy too light a Rotary Cutter, then cut saplings, it will soon visit the shop.
Regardless of what you buy, order chain guards for the front and rear, not rubber guards and not plain metal.
I tried to push them over with FEL but it didn't work so good.
A Ratchet Rake on your bucket will greatly improve bucket grip on saplings to 2" diameter. Chainsaw any more mature.
   / Best way to clear small trees from pasture #15
If you pull those trees, the holes are going to make your pasture bumpy. It's also going to take a lot of time to pull the trees and then what do you do with them?
Although it seems pricey at first, your best option may be to pay someone to mulch them and be done with it.
   / Best way to clear small trees from pasture #16
First thing is the root system on a sweetgum is strong. Cut the tree to the ground and next year you have a sweetgum bush, growing very fast. If the root system is left in place, you best be mowing that area multi times per growing season, for a few years. If you cut the trees or use rough cut mower spray with something like 2,4,D on the stumps. You might be good to use 2,4,D to kill all those trees. Roots and all. Takes coverage of the majority of the tree. Issue with using rough cut mower is tractor tires. It is easy to leave a spike stump just made to puncture tractor tires. (been there done that).
Issue with pulling with chain is, pulling forward tree is being pulled onto tractor and you (unless long chain). If backing up your tires are pulling against the lugs with not as much traction. If you are going to use chain or stump puller and you have a subsoiler plow around the trees cutting what roots you can, will make any pulling method easier. Hey if using fel loader to pull them, do not hook to one loader arm, need to pull from the center of them to prevent twisting the loader frame (again been there). Your rear lift probably has more lift capacity but not as much height.
Method I prefer is I have a 5 ton mini excavator with thumb on it and can pull and stack that size tree in two or so minutes, would expect you could handle one in say 5 minutes. If totally new to excavator watch some youtubes on this and go from there. Would suggest look for someone who has suitable excavator with thumb.
If you have front end loader and have forks or grapple or can borrow that might be best way to get them in piles but a box blade or rear blade turn backwards of the fel bucket are all good tools to push them into piles. As they dry keep pushing them and when you burn push them more and you should end up with good job.
Back to the fel, depending on it's capacity you may find teeth on the bucket can be used to break up roots and get under the tree and lift if out rather easy. Want to not over load the fel.
If you have pile or piles you will be burning, summer is safer to burn in with vegetation green.
   / Best way to clear small trees from pasture #17
A D6 with wide root blade and subsoiler on the back.
Make big piles and burn them at the appropriate time.
   / Best way to clear small trees from pasture #18
I would vote to hire a Forestry mulcher (skidsteer) guy to do the work. I did some damage to my tractor(bent muffler, broken light, tire, etc) before I learned my lesson. He took down up to 8 inch pine and sweetgum and lots of yaupon here in NW Fla and some smaller oak as well. Enlarged a food plot and widened and made new trails throughout the property. Cleaned up a pond levy I would never of attempted with a tractor. His expertise with the machine and speed at getting it done was impressive. He even hit a piece of metal and had to replace a part. All part of the daily game for him.
   / Best way to clear small trees from pasture #19
I had the same situation with a neglected pasture about that size (previous owner) and I was new to tractoring. 30 HP Ford 1920 4x4, FEL. Thorny locusts too, not big but too big to bush hog. Wanted to uproot them so they wouldn't re-sprout and to keep from spreading thorns.
Welded up a 3 PH mounted scoop where the scoop component was a 4' long by 12" wide heavy C- channel with its concavity facing up. Sharpened all 3 segments of its end.
Worked OK in reverse simultaneously lifting and pushing. Stubborn ones sometimes raised one side of the tractor which was a little unsettling. Sharpened end severed the tap root and peripheral roots broke off. What didn't come with the root ball lightly re-sprouted but were easily mowed.
Worse was handling them on the ground. Lined them up side by side and pushed them into a pile with the FEL.
These days, I would buy a stump bucket for the FEL instead. What you can't lift out directly you might be able to pry out with downforce. Sell the bucket when you're done.
pro-tip from my dealer: if you have to work in thorny fields, do it when it's dry to keep the tire carcass perched up off the ground.
   / Best way to clear small trees from pasture #20
I bought this stump bucket last year. It's proved to be just the thing for the type of work you describe.
STUMP BUCKET FOR SKID STEER QUICK ATTACH
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
HUSQVARNA RIDING MOWER 42IN DECK (A56859)
HUSQVARNA RIDING...
