Best Value Plasma Cutter
/ Best Value Plasma Cutter
What thickness of material do you need to cut? Do you have an air compressor? Your question is pretty generic.
Probably under 1/2" most of the time but always will find something thicker that needs cut.
Air compressor is a 80 gallon 7.5 HP dual stage.
just got a 50 from Mark at Everlast. If I was a pro, I would probably get something from the majors, not so much that they are better, just that they are expected in a pro setup and part of the standard communication.
So far, and it hasn't been a long time, the 50 has been fantastic and the price fit my wallet very very well. Mark has responded quickly to my needs and concerns so a plus for customer support so far. My neighbor, who is a pro, came by and took a look at the setup and was very impressed.
I run on a 35 gallon craftsmen which is about the least I think you want.
I will check with Mark.
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
40' High Cube Multidoor Shipping Container (A60463)
40' High Cube...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2013 MACK GU713 CAB AND CHASSIS (A60736)
2013 MACK GU713...
