Best Track Skid Steer Under 7,500 lbs?
   / Best Track Skid Steer Under 7,500 lbs?
Terra Firma Scott said:
NOPE...Customer PAY...
Ouch!!! :eek: I feel your pain. :eek:
Better you than moi!!! Knowing Milton CAT as I do, I'd be instantly bankrupt!!! :(
Dougster
   / Best Track Skid Steer Under 7,500 lbs? #62
Dougster said:
Hi Harold - I am definitely considering the CATs... at least the Model 247 (see my last post above). Looks like I am going to lose that one clean machine that reappeared on eBay. :eek: Looks like there is a new bidder there willing to pay almost anything to get that particular machine. :(
No way I can compete with my thin wallet against a really determined bidder. :eek:
Dougster
I bought a new 247B last year and I love the thing. I also wanted to stay under 7500 lbs and the 247B comes in at 6888 lbs + bucket. With the CAT 4:1, I'm still in the zone. If I did it again, I'd probably spend the few extra bucks for the 257B.
The 257B is a bit heavier but has optional Hi-Flow hydraulics which makes trenching faster, etc, and the bucket goes 7" higher due to the vertical path. The 247B has the radial path. Both use the same 58hp CAT diesel.
I bought the closed cab and the A/C and Heat are the greatest, not to mention the fact that the glass keeps heaping buckets from spilling over onto you when fully raised on windy days.
I rented a lot of different units but bought the CAT because I like the suspension undercarriage, the lack of steel bands in the kevlar/fiberglass/rubber bias ply tracks, overall ride, and controls.
I have a CAT 4:1 with straight cutting bar, dirt bucket with teeth, Virnig rock bucket, and a set of pallet forks (they threw that in to close the deal).
It's really hard to buy a bad skidsteer these days, since the competition is fierce and there are some nice machines out there. I like the CAT and it works well for me. Just one guy's opinion...
   / Best Track Skid Steer Under 7,500 lbs? #63
NOPE...Customer PAY.....Warranty ran out in MAY.....:mad: No help from CAT..I cried for any assistance available even split the bill said NO...Gave the go ahead for the engine R&R since its worth absolutely nothing not running.....
Hard knots....
Just wondering....what caused the engine failure? I haven't seen any fail, but I haven't really heard anything bad about the 3024C mill when I was researching.
I always let mine idle for awhile to cool after running it hard and I always use the glow plugs when starting. I also change oil more often than recommended and stay ahead of the maintenance curve. I also try to avoid running max rpm as much as possible. I avoid the hand throttle unless necessary and use the pedal instead to keep rpms mid range and within reason.
Large flow hydraulic flow implements are never an issue since I use an Excavator or my Ag tractor with 3 point attachments instead of a trencher / breaker / etc on the 247B. This saves high wear and should prolong life quite a bit. I balance jobs across my equipment to put wear on machines that are specifically designed to be best for the task. The 247B will handle whatever you throw at it, but as a Contractor, I am trying to maximize my investment $$$.
Thanks...
In a new machine with warranty, you are probably right. The trick for me will be buying something used that won't break the bank with excessive maintenance and repairs.
Dougster
Kendall69 said:
I think that's the guy that took out my old driveway a few years back! :)
He was never on more than two wheels the whole time!!! :D
Dougster
   / Best Track Skid Steer Under 7,500 lbs? #67
I was considering a rotary cutter for my compact crawler, but a long time friend and machinery salesman convinced me otherwise. Actually he beat me up a little to set me straight. I needed it as I keep forgetting that a wheel machine with large ag tires and pto is much more efficient for certain tasks like mowing etc. Hydraulic motors are evolving but they cannot compete with pto's for power transfer. The skid steer is best at digging and other bucket tasks. Using a $50k skid steer and a $5k mower attachment to do what the old tractor and $1500 brush hog can do is just silly. Yes, I would like to be in my air conditioned cab, but pampering is not worth exposing my turbo to grass particles and the additional track and undercarriage wear, not to mention the degradation that hot oil has on the hydraulic system.
jmf
   / Best Track Skid Steer Under 7,500 lbs? #68
jmfox said:
The only skid steer machine on the market that is designed for tracks is the ASV. Even Cat, who use an ASV track system, have converted wheeled skid steers to track. jmf
I believe Takeuchi pioneered tracked loaders back in the 1980's and it was designed as such from the ground up. They also make the Gehl unit. I just wanted to clear that up in case I ever sell mine someday.
John
   / Best Track Skid Steer Under 7,500 lbs? #69
There’s an internet video out there at one of the ASV dealers that shows several other track skid steers doing the same task, and the ASV blows away all the others.
Hill climbing, going through mud, balance, ride quality etc. Granted it was done FOR ASV, but when you see ASV go up a hill the others can’t, or go over the rod smoothly where the other bounce all over the road - seeing is believing.
If I can find it I will post it.
   / Best Track Skid Steer Under 7,500 lbs? #70
Here JMC. This is a great article that shows machines, who's who, history, prices etc. http://www.compactequip.com/pdfs/ce_june06_tracking_the_industry.pdf
I think ASV was first to market with a compact track loader. Takeuchi came in 1992 but ASV introduced theirs in 1990. Both are designed as track machines from ground up. The ASV in my opinion as a dealer is a far superior design.
Maka
   / Best Track Skid Steer Under 7,500 lbs? #71
Maka
Good article. Thanks. 1992 may be when Takeuchi started exporting them into the US but I recall from a similiar article they were selling them in Japan in the 80's. No big deal either way...
John
   / Best Track Skid Steer Under 7,500 lbs? #72
jmf
x10 Egg-zactley! I have a nice 60" Ford rotary cutter for my Ford 1310 that sells for around $1000 or so new, as compared to the $5000 unit for the CAT.
I also have a Ford post auger that sells for $800 new for the Ford, and the CAT unit is around $4000-5000. I can use the heck out of the Ford and save the hours on the CAT for the high specialty money making jobs... ;)
Sure, the A/C in the CAT rules, but I own cowboys hats, wear a bandana, and drink a lot of water...:D
   / Best Track Skid Steer Under 7,500 lbs? #73
O.K.,
I'll add my 2 cents to this discussion-I am a Dealer (a top five Dealer in the Country for Skid Steers for my Brand), and I rent a lot of Equipment (both the Brands that I represent and others)-
I think Cat has done a great job with the Controls (Joystick, low effort), and they were on the front end of entering the Tracked Market (compared to say, Case New Holland or Deere).
I have had both a 257 and a 257B in my Rental Fleet, and, in my parts of the Country where we have a LOT of Rocks, we went through more Tracks than we should have-the rubber Bogie Wheels get eaten in minus Rock, and we have torn the drive lugs out of 3 sets of Tracks-the problem is, according to the Track Suppliers we have dealt with, that they are an OEM product only-the best price I could find was $1750 per side.
My Manufacturer was quick to point out that the Cat Rental Stores have for the most part gone away from renting the Track Machines, instead they are putting the Loegering Track Systems on their wheeled machines and renting them in that configuration.
We have sold some Loegering Systems and as far as I'm concerned, the jury is still out-Loegering is offering Dealers and extended Warranty on the Drive System of the Machine, which makes me wonder why? If you think about the Chain Drive system on most wheeled machines, and the forces applied by the Loegering System, there may be a root reason.
My Manufacturer says to advise Customers' that (as a rule of Thumb) Tires will cost you about a $1 per Hour to run, Tracks will cost you about $3 Dollars and hour to run, so if you are buying this for a business, you had better be able to recover your investment.
We have a lot of Mountains here, and the Track Machines do well in those conditions, and in Snow they are a treat, but get it on Ice and it's a wounded Duck.
My take on the best Tracked Machine out there? I would say as far as the Track design (which is manufactured by Burco for all three units) would be the Case, Deere or New Holland (that is in alphabetical order)-lots of reasons why (and I think the ASV IDEA is good,it just has a History of continual problems). The Case and the New Holland design are identical, the Deere's is different-
I sincerely appreciate the "professional" input... both your explanations and your recommendations. :) Thank you!
As some of you are aware... I believed that I had purchased a used ASV-30 this week. Yes, a quite small machine for all that work folks want me to do right over top of septic systems. :rolleyes: Turns out that the deal fell through. I posted here about it, but withdrew my post only minutes later after the owner called to advise that he was selling to another party. This was probably for the best... there were some issues with that particular machine... but it now has me back in the market and turning now to wheeled machines since there just aren't enough good, used ASV machines out there... especially RC-50s and 60s... at affordable prices. :(
Dougster
Kendall69 said:
Check this out - click on the hill climb, mud bog
MB Tractor & Equipment
Absolutely great videos!!! Thanks for a good laugh! Needed one right about now! ;)
Dougster
Maka said:
Have you looked on ASV's web site at their used equipment?
ASV - Used Equipment
Maka
Kendall69 said:
Hi Guys - I do understand there are some used ASVs out there to be had if you're willing to pay the big bucks and cross-country transport costs. When I say short supply... I'm talking realistic, "motivated seller" asking prices within no more than say 350 to 500 miles so I can retrieve them myself. Let me be bluntly honest here: I am not rich and, in my current situation, I am not in a position to finance. The bank would laugh at me. Look at something like eBay auction results or regular equipment auction results and compare to these website asking prices. It's like two different worlds. I happen to exist (financially speaking) in the auction prices world. :eek: I need to buy right or I can't buy at all. :(
The same is not true of the wheeled machines. You can do amazingly well for short money in that part of the market. There are countless used wheeled machines out there and it's a total buyer's market. I know of at least 3 or 4 very decent machines within 50 miles that I could buy today. Bargains abound! The real question, of course, is what does a wheeled machine do for me in terms of handling these various "challenging" jobs that are not entirely suitable for the Mahindra. Sometimes a lot... sometimes not so much. :rolleyes:
Dougster
2021 CROWN C5-1000-50 STRAIGHT MAST FORKLIFT (A60429)
2021 CROWN...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
