Best steel for a grapple.
   / Best steel for a grapple. #11
I am about to buy a grapple. I have looked at maybe 20-25 brands.
The AR400 is lighter for similar or better strength.
Most brands seem to use either A36 or g50. A few use AR400 or 450. The cheapest use A36 at 3/8". Most of the heavy duty kick up to 1/2". Severe or Extreme types may go to 5/8" or more.
On a 66-72" grapple, the AR400 models weigh about 200lbs less than an A36 or g50 model.
From what I can tell, CID seems to have the best capabilities for the price. It has been tough to find dealers, but it seems the Bobcat guys around here have them.
   / Best steel for a grapple. #12
I work with ar400 and Hardox450, I would look for the Hardox 450 over the AR400 if possible. The hardox is a little stronger and more formable then ar400.
A36 requires a thicker parts to be strong enough to hold up and A36 has a wide range to their specs.
Grade 80 is a good option but will still have to have thicker part to have similar strength to the 400 or 450.
Ultimately the design is just as important as the material, even the best materials won't hold up with poor design.
I like the smaller landpride grapples but they are a bit simplistic and lacking in design, I've seen number of them with broke/bent tines due to their design (ar400 is brittle and will crack/break when bent too far).
For reference the Hardox 450 is over twice the cost per pound as A36.
   / Best steel for a grapple. #13
Ten years ago when I purchased my Land Pride grapple - wish there were more dealers - here and about. Not the case. Land Pride was handled by Kubota and that was it. My Land Pride has provided exceptional service and if I had to do it again - I would still choose this grapple.
I looked at ANBO grapples. They make a really fine grapple also. For that matter - they will make just about any kind of grapple you want. As long as it is sound from an engineering standpoint. I drove up to Colville and checked them out. Impressive. I just didn't want to ask Kubota to install a grapple that I had not purchased from them.
Anyhow - it all worked out great. The Land Pride grapple and the WR Long third function.
   / Best steel for a grapple. #14
Mine is also a land pride, and has AR400 stickers on it. I have not done any tests to it.
I think I have been fairly mean to mine, using it on some fairly thick roots and such. It has not bent or broke yet. I got it when I got the tractor about 10-ish years ago.
I would buy it again in a heart beat.
   / Best steel for a grapple. #15
I chose this style grapple because I deal mostly with rocks( large and small) and pine tree trunks. I have almost no brush/vines/shrubs on my property. My property is field grass, pine trees and two lakes.
The grapple is called a rock/root or clamshell style. The OM lists AR400 as the steel used to build this grapple.
Anyhow - you should do something like I did to your brush guard. Limbs, sticks and stobs have a nasty way of finding your grill, battery or radiator.
Grapple pic - post #7.
   / Best steel for a grapple. #16
Texas/OK guys and gals, if you are looking for CID Attachments, there's a guy in Denton, TX that has been great to work with.
Pm me if you want more info.
   / Best steel for a grapple. #17
I am looking for a new grapple. The one I first got for my Branson 3515h did not hold up. It is bent up from the soft steel used in it.
I was looking at EAs wicked 55 but since that company is in limbo right now I have been looking at alternatives. EA uses ar400 I believe but I found a nice looking grapple at paramount fab. It uses grade 50 steel.
1 what’s the difference between the two types of steel.
2 what is the best steel to use that is strong and lightweight in a 55-60 inch grapple .
Grade 50 is not much stronger than A36. Land Pride grapples use AR400 or AR450 in the tines, at least.
   / Best steel for a grapple. #18
take a look at Homestead Implements Grapples (I have one, it's great) they use AR450 steel, so you get the strength and weight reduction over standard steel. When I got mine in 2020, they used a mix of AR and non-AR steel. AR for the teeth, etc. I'm not exactly sure what they use where these days, but they respond well via email and phone inquiries.
I got one earlier this year. Homestead Implements Hardox450. Ask nice and they'll even paint it to
match your tractor (my grapple is black, but whatever) :giggle:
   / Best steel for a grapple. #19
I went with AR400 because I could go with lighter weight profiles with the same or better strength of heavy section milder steel grades. The stuff is tough and does not bend easily. Typically used in ground engagement applications.
   / Best steel for a grapple. #20
Grade 50 is about as strong as a grade-5 bolt. That's how I remember it. It's stronger than A36 by nearly double. AR400 is nearly twice as strong as Grade 50.
2021 JOHN DEERE 7R230 LOT NUMBER 208 (A53084)
2021 JOHN DEERE...
JOHN DEERE 8R 340 LOT NUMBER 96 (A53084)
JOHN DEERE 8R 340...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
