Best nineties tow vehicle
   / Best nineties tow vehicle #31
I have never broken a solid axle, in a Jeep on Rubicon, or pickup out hunting. I broke a Ford F250 IFS working on my 5 acres though...
I thought the Twin I-Beam rode fine. But :D
Both of the ones I had sagged like crazy. And, I see that all the time looking at F250/350 with that front end, and the leaf springs. The leaf springs do not work as well/last when the axle pivots on an arc from the center attach point. It wears the springs too much. The system works much better on the F150 with coil springs.
When I switched my F250 long bed extended cab to a straight axle, it went from turning like the Queen Mary to turning on a dime. I was shocked by the huge difference in turning radius, shocked... And, very happy.
The IFS in the F250 was a hybridized Dana-44, the Dana 50. The Dana 60 straight front axle is a lot beefier. I had the IFS apart to replace broken axle shafts; it was definitely weaker than the beefy Dana-60.
The Sterling rear axle in the Ford is a good strong axle.
I was never excited by the GM IFS. Rode nice, but sat low and limited articulation.
Mine had the ZF 5-speed. Not a very strong tranny, and 1st gear was more car like as compared to a creeper first gear.
Which 5spd are you referring to? The NV4500 was a great tranny.
whew! i feel just opposite, first i understood we were talking about 3/4 ton pickups do you think gmc or dodge go any better? off road the twin i beam can carry more speed than a solid axle.i use a 3/4 ton truck to catch and doctor cattle,solid axles will break off.the later models twin i beam is heavier. as far as a stick it is the same brand as the gmc which are a step above a dodge [5th gear falls off].i had 5spd ford with about 300,000 on it when i sold it.i would get a auto anyway.i like the 351 ,it is strong enough to pull a 20,000 lb trailer full of hay to the barn or a 14000 lb cattle trailer to the sale barn.if going further get a diesel.empty the mileage is good for a 3/4 ton gas. for me, i like the twin i beam robertn has a point about a solid axle being cheaper to run.if you want a solid axle,get a single rear wheel 350.
   / Best nineties tow vehicle #32
99 F-350 crew cab 7.3 PSD can't beat it room and power:thumbsup:
Yep. I tow about 11K with an early '99 (smaller turbo), 4x4 crew cab everyday. This thing just won't die! It has about 280,000 miles on it right now. The trans was the achilles heel, but once I found a good trans guy it's been an awesome truck. I've had a Hypertech programmer installed at the top setting since 90K. Excellent power...although I've always been partial to the Cummins and styling of the late 90's Dodge. Go figure.
I did have a '91 Chevy dually with a 454. Most comfortable truck I ever owned. I loved that truck and the big block, but no way could it hold a candle to the pulling power of the Powerstroke.
Wow Robert, I think I just coughed up a little dust from the Little Sluice. Man I miss that trail!
I was going to say that 95 was the last year of the TBI which was good and bad. Good, they are dead realiable and dirt cheap to buy parts for. Essentially the last of the simple trucks. They made crap for power but made up for it in simplicity and reliability. Me and my dad and mom are both hanging on by dear life to our 95 chevy's for that reason. They became a little more complicated every year after that, but made more power and had other benefits. Sounds like you have the vortech though, they were pretty good too. THe only known problem I think they had was intake seals would go but that isnt a terribly difficult repair to make. Im a big fan of the 90's GMs but there are other good options too cummins and 7.3 powerstroke being the best if power is a concern. If you want something that can be maintained extremely cheaply and easily the Burban is a good option for you. The diesels wont be as cheap or simple to maintain most likely.
I tell ya, the big block in my buddies burban feels every bit as powerful as my ole cummins...and my cummins wasnt completely stock either.
really impressive power out of that motor.
And yes, the maintenance on a diesel is more involved/costly (the water filter on the cummins was a ***** to get to)...plus the fuel is about 30 cents more expensive per gallon.
I imagine there might be a cure for the intake seals on the vortec...maybe an upgrade that reduces your problems with them?
what is your experience with the transmissions?
My neighbor that earns his living traversing California with a 24' tag trailer has owned many vehicles over the years... all bought new.
He said, hands down the best so far was his 99 Ford Excursion with Diesel... zero problems and very comfortable plus room for passengers and gear inside.
His newer vehicles had more power... they also have had serious issues... both gas and diesel... all covered under warranty...
I had looked at the excursions...but they are all over 11K or so.
also, they had their fair share of problems...I read that the steering boxes go out, along with the ball joints and some other things at way under 60 or 70K miles...
but I imagine the trannies and engines are pretty bulletproof.
but is the excursion worth 5 or 6 or 7K over the suburban?
If it is a Vortec, buy it. $4800 is IMO a fair price since you know he has taken good care of it. I think it will have vortec stamped into the heads. If you check the RPO sticker in the glove compartment, it will have code L29.
The valve cover gasket all leak eventually also.
thx
I'm beginning to think you may be right....perhaps that is the best vehicle for the price for me
   / Best nineties tow vehicle #36
on my farm we have broken a solid axle off twice.once broke the spring hangers off and once broke the lower ball joints off. i almost forgot about when the pipe came out of the chunk.you are right about the shorter turning radius on the solid axles.the 90s model 350s have solid fronts.where did your dana 50 or 44 axle shaft break? i never broke a axle shaft but have other parts. the 50 axles are heavier.the sagging is due to weakening springs and the bushings wearing on the pivot point.it is more maintenance on a twin i beam. i forgot about there being 2 different stick transmissions in those trucks.i had the heavy one.i got 2 jeeps in the barn never broke a front axle off them either.i always keep a old truck to use off road and catch cattle with,i have had the best results with twin i beam trucks.
   / Best nineties tow vehicle #37
Depends on what you want. The Excursion is heavier, a little more roomy, with the 7.3 it will certainly tow with more confidence. Do you really want to pay a bunch more for a work truck? It does not seem like you plan on driving it that much or care about creature comforts.
I do not think the Ford V10 will compare favorably to the Vortec 454 and the smaller gas engine is not in the same class.
creature comforts are somewhat important.
I want working a/c and comfortable seats...but I dont need navigation, for instance.
I currently own four vehicles.
As a result, no single vehicle gets driven the national average of 12K miles per year.
They all get about 3-6K miles per year, even with the daily 35 mile roundtrip commute to work...due to the fact that the same car isnt driven all the time.
They are all used, and we have no car payments....and if one breaks down, I have three spares.
Yes, I've had two break down at the same time :laughing:
I'm not sure how much the excursion weighs, but I bet it aint that much more than the suburban...and I bet the tow capacity of that burban is pretty close too
   / Best nineties tow vehicle #39
For your uses, the 'burban would be the best bet.
It's the combination of cheap to buy and power that you are looking for.
There may be others better, but they will be more expensive.
BTI
BTI
agreed.
I love a pickup bed for just throwing stuff in when needed.
but I cant get over how much **** room is in that suburban...
I think my mind is made up,
thx everyone
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2015 VOLVO VNL SLEEPER (A59575)
2015 VOLVO VNL...
Mini John Deere Truck (A55853)
Mini John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
