Best Modifications I've Made!
/ Best Modifications I've Made! #1
mffarmall
Colorado
Farm Pro 2425, MF 50, JD B, Farmall Super MTA
Two of the best things I have ever added to a tractor.
1. Put an LCD light on the canapy. Got it from the dollar store 3 AAA and mounted it above the dash. Great because I can turn it on and use it while I drive or after I turn off the tractor. It helps if I'm working on it. And the best thing if I leave it on, I still have a battery in the morning.
2. Found an old 4' electric PVC pipe and I mounted it on the side of the role bar. I have enough room to put two shovels and a manuer scoop. I have never hit my head or shoulder on it. I can't count how many times I have been out and needed a shovel for something.
/ Best Modifications I've Made! #2
Tool box is next for me. I hate running back to the shop. Now I just keep a large adj wrench hanging from the PTO engage lever. Bucket hooks would be nice, and thumbs for the bucket if I get to keeps dreaming!
Patrick T
/ Best Modifications I've Made! #3
I Run an ad in the paper wanting plastic pipe and somebody called and gave me about 200 feet of used 4 inch.
/ Best Modifications I've Made! #4
Cool adding a couple little things like that to make life a little easier. I did the same since I was always working out on my rural property and eventually needed something I didn't have with me. So I added a bunch of stuff such as clamps to carry shovels and rakes, two tool boxes and chain boxes, drink holders, ash tray, 2 way radio pouch, extra lights for night work and even a gun scabbard.
Now life is good.:)
/ Best Modifications I've Made! #5
Hey Rob,
Do you have a write up on your cup holders? I NEED ONE!
Thanks,
Rick
/ Best Modifications I've Made! #6
yesterday, I was boxblading a long gravel road on my property; one thing I MUST get is some kind of big rear view mirror to hang from the canopy. Man, I have one SORE NECK!!!
/ Best Modifications I've Made! #8
Larry,
You are "THE MAN" Where did you find the mirrors and cup holders?
Thanks,
Rick
/ Best Modifications I've Made! #9
Momboy007 said:
Larry,
Thanks,
Rick
Hi Rick,
Got the mirrors from a TA truck stop,cup holders I ordered at a Kobota tractor dealership 12 bucks each for the cup holders, I forget what I paid for the mirrors something like 15 ea.
Larry
/ Best Modifications I've Made! #11
Look in the mirror section of most any auto parts store, you will usually find an assortment of replacement units, most with a swivel ball mounting point.
/ Best Modifications I've Made! #12
Hello All,
Here is my best Modification to date.
I decided to do the Guglio retrofit, which is a new NAPA 182 degree T-Stat that Larry retrofits and then customizes a special gasket to fit the Chinese tractors.
I installed it, then fired it up and because it is warm outside, it came up to about 90C within 5 minutes and then I worked the tractor for the next 2 Hours, the tractor had more power than it has ever had.
The temperature in the past, even on the hottest Southern California day, never got above about 40C. I think it is using less fuel as well and has no hesitation like before.
Pictures and the entire simple procedure to follow
Thank You Larry for such a great kit, I think every Jinma owner should have one after installing my own
Rick
__________________
Jinma 304
/ Best Modifications I've Made! #13
Bob Rooks said:
Please tell me how that part works. :confused:
"A good wife can bring balance to your life".........
Larry
/ Best Modifications I've Made! #14
Larry-
I know that the picture is not of you and Esther because you both have a full set of teeth:D :D :D
Bob-
the answer is love- that's how it works and the only reason why my better half is still around -Ed
That is a great picture.
The best thing about my modifications is that I have broken the light twice and replaced it for $1 each time.
I have added a tool box and found that it is very helpful except for the fact that I need to remember to put my tools back into it.
I carry a rubber hammer for implements, it really saves the feet from kicking things on.
2013 Volvo VN Semi (A64047)
2013 Volvo VN Semi...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2025 LandHonor MGB-72-44W Rotating Grapple Skid Steer Attachment (A61572)
2025 LandHonor...
2012 MACK GRANITE-GU713 (INOPERABLE) (A63569)
2012 MACK...
2010 MACK PINNACLE(INOPERABLE) (A63569)
2010 MACK...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
