Best Mod/add on to compact tractor or attachment
   / Best Mod/add on to compact tractor or attachment #31
My best Mod/add list is:
#1 add on is the Sims hard sided cab,
#2 is the Sims heater,
#3 is the block heater,
#4 is snow chains on all four,
#5 is the MF front mounted snowblower,
#6 is the front mounted dozer blade,
#7 is the Backhoe Thumb,
#8 is the front bucket brush rake,
#9 is the 3 point weight box,
#10 is the front bucket tooth bar,
#11 is going to be purchasing a grooving/sipping heating iron tool,
KC :D :D :D
   / Best Mod/add on to compact tractor or attachment #32
I still have LOTS of stuff I'd like to modify or add, but I'd have to say the one item I use more than any other --especially this winter!-- would be the M-F 2360 front-mount snowblower.
(Finally finished cleaning up Friday's 14" storm yesterday; now have another 2"+ of "flurries" on the ground and it's still coming down....:p)
Second-best mod would be the addition of a second engine block ground cable; tractor is still starting as though it just got a new battery.:thumbsup:
   / Best Mod/add on to compact tractor or attachment #33
A little late and probably a repeat but my Shackle Mounts on the FEL instead of Hooks has my best add-on to date.
With Shackle Mounts I can use shackles of course, hooks of any type with one bolt mount or any type of Utility Tool that hooks up with the one bolt setup as a shackle.
I made up a two to one chain cling for a center pickup instead of using a center mount on the bucket, this helps balance the load some.
My only problem is the size of the Shackle Mounts, a little bigger than I wanted but they will carry all or any weight I add to my little tractor (SC2450).
   / Best Mod/add on to compact tractor or attachment #34
Single best mod I made was converting to skidsteer style quick attach.
:thumbsup: ... Then add:
Tilt-Tatch Attachment - Bobcat Company.
For the larger cuts. It is the lightest of them, made from hi strength steels ... but still weighs about 300#. It stands up to the 7520 and provides so many benefits I cant justify removing it even with weight penalty.:cloud9:
larry
   / Best Mod/add on to compact tractor or attachment #35
case 1975, 446 garden tractor. remove the cheasy stock battery. and put a reg car battery between the rear tires.
   / Best Mod/add on to compact tractor or attachment #36
My center bucket chain hook
My backhoe thumb
Joel
   / Best Mod/add on to compact tractor or attachment #37
Brush/root grapple. Even with the fit problems I had with mine when I got it, it has still been an amazing tool for working with brush, firewood, logs, etc
Grapple grapple grapple. can't say it enough
   / Best Mod/add on to compact tractor or attachment #38
I'll have to get you some pix, but I "frenched" in a 2" trailer reciever tube into the top of my loader bucket. That way I could put in a hook, ball hitch, pintle hitch, bale spear, you name it without changing the bucket or attachments.
   / Best Mod/add on to compact tractor or attachment #39
Turf tires.... No grooving necessary.
   / Best Mod/add on to compact tractor or attachment #40
Since my tire groover is still on its way to me, I'd have to say my best, most productive overall modification to the tractor is the added hydraulics. The three spool valve I added has opened the door to many more capabilities, like : top and tilt, remote rake swivel, snowblower chute rotation, tree shear (oops, havent built that one yet).
42013 (A51691)
42013 (A51691)
1000000 (A47477)
1000000 (A47477)
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
