Best Mod/add on to compact tractor or attachment
   / Best Mod/add on to compact tractor or attachment #51
Is that an iceberg in the first picture between the truck and trailer?
Yep it sure is. We get a pile of them around here. Just in case you enjoyed seeing them here's a few more. This one was a mile long and 1/2 mile wide.
   / Best Mod/add on to compact tractor or attachment #52
   / Best Mod/add on to compact tractor or attachment #53
Since my tire groover is still on its way to me, I'd have to say my best, most productive overall modification to the tractor is the added hydraulics. The three spool valve I added has opened the door to many more capabilities, like : top and tilt, remote rake swivel, snowblower chute rotation, tree shear (oops, havent built that one yet).
I like the use of the multi colored zip ties-it makes it easy to plug in the right attachment hoses to the correct QCs. I use black and (NH) blue caps and plugs on my stuff when disconnected but that just insures the proper hydraulic in/out flow when connected, not the which set of QCs to go to per implement. I'm off to the color coded zip tie store!:thumbsup:
Tell me about the one lever with the blue ?foam? wrapping on it.
   / Best Mod/add on to compact tractor or attachment #54
Simply awesome. Wish I had an ounce of your fabrication skills...
   / Best Mod/add on to compact tractor or attachment #55
Pretty cute indeed! Any photos of the shovel attachment?
I think somewhere to stash the pitchfork and/or shovel is greatly needed. I also am impressed with the flashing parking brake light. Off to walmart...
   / Best Mod/add on to compact tractor or attachment #56
   / Best Mod/add on to compact tractor or attachment #57
Well, no wonder I don't notice the parking brake light-it seems I have an econo-model that's made without one-either that or it is very well hidden. My son seems to think this is an easy fix...anybody put one in from scratch and have pointers? I would even consider installing an irritating ding ding ding noise at this point. My response to having forgotten the brake several times, has been to start not using the parking brake when getting out to open gates or use the pitchfork. I'm sure this is not Kubota's intent, as the safety idea is to use the parking brake....The tractor is an m7040 (you know, the one with the red-hot, smoking brakes!).
Thx,
Suzy
   / Best Mod/add on to compact tractor or attachment #58
Thx,
Suzy
Suzy I'm not familiar with the M series tractors. Your tractor don't have a park brake light in the instrument cluster? Mine Grand L do but I still kept missing it so that's why I put the other flashing light on it. In my case I just spliced into the existing brake light micro switch for a brake light in the dash. If your tractor has a brake switch I can provide a few detailed photo's that may help you.
   / Best Mod/add on to compact tractor or attachment #59
Tatro grapple, WR Long 3rd function valve and toothbar for loader bucket. My EX3200 Cub Yanmar is a tree moving machine with these mods.
Cowdoc -
How hard was it to install that 3rd function valve. I have the same machine and will need to do this sooner than later. Any feedback would be great.
Moondog
   / Best Mod/add on to compact tractor or attachment #60
RonMar said:
If you do much land clearing and work with wood/brush, a bucket grapple makes a big difference in how much you load in the bucket and saves a lot of off/on trips to load the bucket with a decent load by hand... Bucket forks in conjunction with this are even better. If I do any hand work i leave a pile. The grapple allows me almost always roll up and pick the entire pile...
Next to that a drawbar plate with welded on hooks to allow me to quickly attach a chain to the drawbar.
Like the tire sipping, I will have to look into that, as a little more traction would always be welcome:)
I've been wanting to add some lights on my kioti LK3054, I've even purchased two round utility lights cheap basic one wire self grounding via metal bolt and bracket spot light style. & I bought two rectangular tractor implement lights that create a trapezoid beam pattern. I've been seeking advice as to which ones to use whether or not the ROPES is best place to mount, if not then where? Do you have a toggle switch or are they set up to power on w/headlights any advice would be appreciated ..... B.T.W. I don't have a loader attached I just need more lighting.
JOHN DEERE 4320 EHYDRO TRACTOR (A57192)
JOHN DEERE 4320...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2020 FORD F250 XL EXT CAB TRUCK (A57192)
2020 FORD F250 XL...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
