Best Mod/add on to compact tractor or attachment
   / Best Mod/add on to compact tractor or attachment #1
Green4310TLB
PA
Deere 4310
I added this site to my favorites today. Looks like a pretty creative bunch so... I present this question. What is the best modification you have made to your tractor or attachement ? I use mine to cut/move firewood, move dirt, and generally dig in the dirt. Basically a homeowner machine that the wife is not afraid to drive. Already have the loader, planning how to add a grapple to the bucket and then a bale spear. I am a pretty good welder so bigger project are ok too. Thanks in advance.
   / Best Mod/add on to compact tractor or attachment #2
Bucket teeth and bucket hooks
   / Best Mod/add on to compact tractor or attachment #3
Loader mounted quick hitch.
   / Best Mod/add on to compact tractor or attachment #4
Toothbar and Pat's Easy Change... Best stuff I ever added.
   / Best Mod/add on to compact tractor or attachment #5
Single best mod I made was converting to skidsteer style quick attach.
   / Best Mod/add on to compact tractor or attachment #6
Tatro grapple, WR Long 3rd function valve and toothbar for loader bucket. My EX3200 Cub Yanmar is a tree moving machine with these mods.
   / Best Mod/add on to compact tractor or attachment #7
Well mine are pretty minor, but here they are:
1: Coated the steel floorboards and center hump with Plasticoat pickup bed liner material. Works better for traction and wear resistance than I would have imagined, and I think it looks good too!
2: A set of Carter quick hitch hooks on the 3pt lower arms. They work well and are cheap.
3: Welded on some chain hooks on the bucket, gotta have these. just wish I had waited until I got my DC welder, so the welds would have looked a little prettier. but the old AC tombstone got-er-done.
James K0UA
   / Best Mod/add on to compact tractor or attachment #8
I have many on my Mahindra 3215, and at first I was going to say my top and tilt hydraulics, but thinking about it a little more I would say the suspension seat that I had the dealer install would be sorely missed. The factory spring seat is not very good in my opinion. Here's a link to the modifications that have been done on the tractor. :thumbsup:
   / Best Mod/add on to compact tractor or attachment #9
OH theres sooo many..... Air ride seat with fore/aft movement. Hyd top link. Quick Hitch and adding a 2 5/16 ball to the top of it to bob goose neck trailers around. Tilt meters (both directions) for making water run the direction you want. Adding grapple teeth to a seperate bucket. Adding hyd hoses from the rear to the loader for the grapple and hyd post hole digger. Just for starters.
   / Best Mod/add on to compact tractor or attachment #10
BEST MOD I EVER DID, WAS GROOVE MY TIRES!
Seriously, the traction more than Doubled, I rarely use 4x4 anymore. Its amazing! :thumbsup:
I suggest this to anyone looking for more traction from a R4.
REARS
FRONTS
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
17307 (A55853)
17307 (A55853)
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2022 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A52707)
2022 CATERPILLAR...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
