Best method for a tractor to move/haul/process downed logs?
   / Best method for a tractor to move/haul/process downed logs? #11
What are you planning on doing with the wood once you have it captured in the field?
2' diameter wood only takes a couple of minutes to make a cut in: cut in half and your issue is more manageable- cut more times until its totally manageable. THEN, as LD1 says, grapple it (into a low trailer so you can take it back out with the tractor+grapple).
But, if it's really only a one-time need (you wouldn't require any further use of say a grapple on your tractor) then rent something and be done with it.
If you gots lots of money check out Xfaxman's setup (Bobcat V417 is awesome!).
   / Best method for a tractor to move/haul/process downed logs? #12
Grand l6060 primarily a logging machine on my 9+ acres of completely fire destroyed forest land. Been logging it for the last 2 years with a grapple on the front and a skidding plate on the back. Ill post some pics when I get to the house this evening. Works really well. Had to fill the tires though, I have some steeper slopes that it was really tippy on without fluid in the tires. Was doing it with a 4060 and it just wasn't enough tractor. Watching the loader arms (805) wiggle around scared me a bit with the logs I was moving. The loader arms on the 1055 don't flex at all with the bigger logs.
   / Best method for a tractor to move/haul/process downed logs? #13
Thanks, for those that haven't seen it: http://www.tractorbynet.com/forums/...mpact-telehandler.html?highlight=#post3243370
About 6 acres of downed trees and debris is flat. Maybe 2 acres with moderate slope. There is a 6 foot bush hog at the property. I might have access to a crawler tractor, not sure. I am not familiar with M or MX models but will investigate. My situation is I can work there for a day or two at a time only. So this will take some time. I am open to the best tractor fit.
I looked at a Kubota M6060 today, 4wd, hst, with LA1154 loader, 3rd function valve, and 4 in 1 bucket. Reaching up toward $40,000. The salesman seemed to think the 4 in 1 bucket would work for logs. I have never used one, but it seems to me a 4 in 1 bucket is a wonderful thing except a grapple would be more useful for logs. Am I on the right track?
   / Best method for a tractor to move/haul/process downed logs? #16
I maintain 23 acres with a Kubota L2501, Farmi skidding winch and Landpride grapple. Does everything I need.
ImageUploadedByTractorByNet1476230428.070549.jpgImageUploadedByTractorByNet1476230457.155312.jpgImageUploadedByTractorByNet1476230479.506185.jpg
   / Best method for a tractor to move/haul/process downed logs? #17
For woods work, and moving brush/logs....I would want a grapple over a 4n1 any day.
The M6060 has some pretty good lift power too. Load them tires, and get something on the back that weighs a ton.....and you just might be able to move them 2' diameter 26' logs around.
   / Best method for a tractor to move/haul/process downed logs? #18
What no one seems to be grasping is that the wood (to my understanding) is like blowdown and is likely to be a chaotic mass of tangled mess. Like the numerous acres we have after a tornado came through a few years ago.
In our case, even professional loggers would only touch a little around the edges. To actually extract anything out of there would require stout chokers and a lot of chain to drag stuff out one tree/log at a time (while any workers were WELL away from the action). A heavy 3-point winch would probably do better.
   / Best method for a tractor to move/haul/process downed logs? #19
Just FYI, if you are thinking of picking up with a grapple...
for a 2" diameter x 26' long log the weight for a couple of species - one at the light end of the spectrum, the other at the heavy end (weights assume green logs)
White Pine = 2900#
Red Oak = 5200#
   / Best method for a tractor to move/haul/process downed logs? #20
A winch and self releasing snatch blocks can weasel out logs from a mess like that.
Online Buyers Premium (A55272)
Online Buyers...
2008 Isuzu NPR-HD Landscape Dump Truck (A56858)
2008 Isuzu NPR-HD...
2015 Peterbilt 320 Trash Truck (A55973)
2015 Peterbilt 320...
air compressor (A55758)
air compressor...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
2023 CATERPILLAR 259D3 SKID STEER (A52709)
2023 CATERPILLAR...
