Best lubricant for moving parts of cattle squeeze
   / Best lubricant for moving parts of cattle squeeze #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
I bought a used Powder River cattle squeeze. It is in good working condition functionally, but has rust in places and moving parts need some lubrication. We are removing rust and will repaint those areas where appropriate, but I am wondering what would be the best choice to lubricate the moving parts and reduce friction. I am thinking WD-40, or a teflon product for some parts, and maybe even grease for other parts. Suggestions will be appreciated. Not the most earthshaking issue, but just wondering.
   / Best lubricant for moving parts of cattle squeeze #2
I use anti-seize on pivot points that are subject to the elements. It is less prone to washing away and provides a protective coating that resists corrosion.
   / Best lubricant for moving parts of cattle squeeze #3
Been using blaster silicone spray. You may have to apply it more than grease or something else of a similar consistancy but it doesn't pick up garbage like grease does so I would rather apply it once every two weeks with a few squirts than break it down clean off the muddy grease and start over. Some places grease is what is needed. I use the silicone on all my door bushings and hinges, all my tractor pins that blindly slide, clutch bushings in my truck, any place I would prefer not to collect dust and grit.
   / Best lubricant for moving parts of cattle squeeze #4
On the sliding pieces I like wax, it doesn't hold dirt and dust manure slides off and it doesn't build up.
   / Best lubricant for moving parts of cattle squeeze #6
I don't believe that WD40 and like products will give you any
lubrication.
Maybe check out some of the silicone sprays???
willy
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2025 JMR 40in Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
