Best Implement to Maintain/Groom Driveway
   / Best Implement to Maintain/Groom Driveway #1
MikeTipton
I have a BX24 and gravel driveway. What would be the single best implement to maintain and groom the driveway? And how would you do it?
Thanks,
Mike T.
   / Best Implement to Maintain/Groom Driveway #2
I use my rake and set it to an angle to bring the stone back on the driveway. Make a pass or two on each side and then I set it back to the normal position and make a final pass right down the middle spreading the gravel out without removing all the crown. I do this at a pretty quick pace. I also do this often to keep weeds from growing and it seems easier the more I do it. Good luck!
   / Best Implement to Maintain/Groom Driveway #3
I also have a BX and bought the DR Power Grader. Worked really well. First I ran down the driveway with the bucket down to scrape off the grassy hump in the middle, then I made several passes with the grader. Driveway looks like new after probably in excess of 20-30 years without maintenance. I would recommend the 48" model for a driveway since it is easier to manuever with it.
   / Best Implement to Maintain/Groom Driveway #4
I use a chain harrow to drag mine...
   / Best Implement to Maintain/Groom Driveway #5
Thanks,
Mike T.
How long is your driveway?
If it isn't too long the DR Power Grader is really good. I just so happen to have one for sale too. My road is just too long for it. I bought a Road Boss and don't need the DR any longer.
   / Best Implement to Maintain/Groom Driveway #6
by groom you mean move the surface gravel around?
i love my rear blade... allowing me to pull loose gravel from the edges back to the middle etc.
   / Best Implement to Maintain/Groom Driveway #7
Thanks,
Mike T.
I agree with Keving, if only one implement, get a landscape rake. I find that gauge wheels help a lot with getting even results and setting the crown.
I also have a tilt blade that I use for the ditch line and for making water bars to channel water off the driveway.
I have a landscape rake. Any more suggestions on how to get the most use out of it? Do I just walk into my local farm supply and ask for gauge wheel?
Mike T.
   / Best Implement to Maintain/Groom Driveway #9
After years of using a back blade, I just purchased a 7' rake. For me, it does a better job than the back blade. I was sold after the first use. My drive is 1400 feet and rises 250' in that distance.
Mike T.
Mike - do a serach and you will find lots of discussions about gauge wheels - including the very high prices. There are several threads about building your own, which I plan to do. I asked the dealer where I purchased my rake and he had never heard of guage wheels on a rake. Went to the LandPride dealer and even he had to look them up. The LandPride price was just about what I paid for my generic rake.
   / Best Implement to Maintain/Groom Driveway #10
Mike T.
Mike,
Gauge wheels were an option on my land pride rake, see:
Land Pride LR15 Landscape Rakes
You can also get an optional grader blade for the rake however I have a separate rear tilt blade:
Land Pride RBT15 Series Rear Blades
I don't know if your rake can easily accommodate wheels. Gauge wheels allow for precise setting of the depth of the cut as well as side to side tilt.
I live in snow country so each spring I use the rake to repair the gravel drive after winter plowing. First I pull the material back in from the sides with the rake angled inward and the outside gauge wheel set for a deeper cut. As I make two or three passes in each direction, I move toward the center of the driveway. The result is a cleaned out shoulder and a pronounced crown. I finish with a very light straight cut down the center to ease the crown a bit.
I then use the tilt blade to reform any water bars that the snow plow or rake had flattened. On occasion the ditch line needs cleaning out and if so, I would have used the tilt blade for that prior to the above raking.
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
KUBOTA U55-5 EXCAVATOR (A51242)
KUBOTA U55-5...
Informational Lot - Shipping (A52128)
Informational Lot...
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51242)
2024 INGERSOLL...
