best implement for pipe laying?
/ best implement for pipe laying? #1
evofxdwg
middle GA USA
Yanmar 1610D
New tractor owner. I have a 20HP tractor. Wondering if there is a good 3pt implement to trench for laying sprinkler pipe. Need to go 10"-12" deep on a narrow trench for 1" or smaller PVC. Need to leave loose soil on top not in trench. Soil here is sandy, no rocks, but a few patches of harder clay (which would be busted up anyway before i put in sprinklers). . Closest i have seen commonly called middlebusters and subsoilers. But nobody seems to advertise an implement specifically for laying pipe. There must be a problem with this idea since Ditchwitch is common. Any comments?
/ best implement for pipe laying? #3
If you use the flexible "pipe" you can feed it through a tube that sets behind the "tooth" on your subsoiler. Figure a way to hang the spool of "pipe" on your ROPS. so it rolls right off. Leave enough stick out on either end to attach to. The hardest part of the job is hangin' the "pipe" on the ROPS.
/ best implement for pipe laying? #4
There was a guy on here that had used a single shank subsoiler to lay in electrical cable. He had welded a pipe of the appropiate diamenter to the back of the shank that fed the wire to the bottom the shank.
/ best implement for pipe laying? #5
</font><font color="blue" class="small">( The hardest part of the job is hangin' the "pipe" on the ROPS. )</font>
I rolled my pipe out along the route I wanted to lay it. I then clamped a couple of 1X2 pieces of wood to form a "V" at the top of the ROPS then just ran the pipe up over the hood of the tractor, thru the "V" and down to the sub-soiler/pipe layer. There's a thread with pictures of how I did it somewhere in the archives...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
Volvo VNM (A63689)
Volvo VNM (A63689)
2008 EZ-GO GAS GOLF CART (A63276)
2008 EZ-GO GAS...
