Best garden water pump?
/ Best garden water pump? #1
Fuddyduddy1952
Super Member
john deere
I have a good spring fed creek I'd like to rig up an irrigation pump for a garden. One area would be close to the creek, so lift would be 10-15 feet and close to creek. We're not planning on a huge garden, about 40 ft X 80 ft would be fine.
Another area available would be uphill a ways, so lift 100 feet and would need 500 feet of hose. Same size area.
I see solar pumps which I'm sure would work near creek and Harbor Freight has a gasoline pump that should work for uphill.
I'm guessing in dry weather watering twice a week for and hour would be fine?
Any experience is appreciated. I'm hoping to not spend a fortune (maybe around $300-$400?). Thanks!
/ Best garden water pump? #3
Don't forget that there are hydraulic ram pumps available. No gas, electricity, or solar needed, just flowing water.
Hydraulic Ram Pump
Hydraulic Ram Pump
I bought a hydraulic ram pump. It really wasn't efficient and I spent hours fooling with it.
WHERE??
"Dry weather" means it hasn't rained in a couple of days in Mississippi, a couple of months in some places in Arizona.
South Central Virginia.
We haven't had a decent rain in two weeks. Overall rainfall is pretty good, just thinking of garden I'll plant.
/ Best garden water pump? #7
As a rough approximation, if you are pumping water up 100 ft, you will loose around 43 PSI to gravity. (need 100 psi at the pump for 57 psi at the garden)
Bruce
