Best engine braking UTV
/ Best engine braking UTV #21
Thanks for all the info. Now I need to look into the laws of the over 30 mph and under 30 mph. I want to cruise down the road w/ triangle and I believe it is illegal if they go over 30 MPH because they are no longer slow moving. I'm going to look at the Kubota 900 in camo. I got a few prices and the lowest was 13,499 in camo w/brushguard standard. I would like to buy out of state to save that 8.75% sales tax. The reason I need engine braking is I checked the grade on one of my trails and my Bushnell rangefinder put it at 17 degrees. It is pretty steep and gets a little hairy even on my quad.
i have never checked the grade on some of the logging roads i work on, but just by guessing some have to be 30 degrees or more. i would even say 45 in some areas i have been on and that is if 0 is flat and 90 is straight up and down like a cliff. the rtv does great!
/ Best engine braking UTV #22
I think the Kubota has it for engine braking. My roads in the woods aren't steep like some of you guys but still enough that breaks would be a good idea. Hauling with my 900 i don't believe i've ever used the breaks. If your not payig attention when you let off the throttle pedal you might wear the steering wheel, some say its to much hold back but i like it.
In my opinion the kubota has a built in "Jake" break that works better than my 2010 International road tractor!
Here's a couple pic's of my loads .. .John
/ Best engine braking UTV #23
JPM I really like those bedsides with the axe mount. Do you have any other photos of that setup?
/ Best engine braking UTV #24
We own three Yamahas,engine brakeing is the best in the business..
The Grizzly 700FI and the Rhino have weak unreliable engine braking, there is a one way bearing which fails often, google it, and my vehicles have done 3300 hours and nearly 5700. You can modify the vehicles to improve it with an aftermarket kit (something about lugs from memory), but i resent having to spend more out on vehicles that should do the job from day 1. The issue happens if you use trailers, I doubt you'll notice it, just driving the vehicle round.
The only parts that fail on these vehicles are Stator Coils and Engine Braking for typical farm use.
The engines are bullet proof, nearly 6000 hours, no rebuild, that said it does use oil now, but always starts, even if the plug needs cleaning once a week, and they get used 2-3 hours a day minimum. The differentials, and drive shafts are as well.
/ Best engine braking UTV #25
I've only used a Polaris Ranger 400 and now my Kubota RTV-X900 and the Ranger drove me crazy as it would free-wheel down our hills and I had to ride the brakes. The brakes were great, but with a load in the back it made it difficult not to heat the brakes up. Now with my RTV I hardly use the brakes at all! I love the HST transmission - I knew I would as I've had a Kubota B7800 with a HST transmission for 12 years.
For creeping up and down steep hills I highly recommend the Kubota RTV series.
/ Best engine braking UTV #26
I'm real happy with the way the transmission braking works on my RTV. I have read were some of them work to well though and well about put them though the windshield. For me mines about perfect.
/ Best engine braking UTV #27
I have the Deere 855D...engine braking is quite good...in fact, sometimes too good! My guess is the diesel models (in general...not just Deere) do better due to the higher compression ratios of the engines.
But a real comparison would require side by side testing of multiple brands...all we're doing here is providing anecdotal evidence.
/ Best engine braking UTV #28
this mite sound nuts but the ranger has to have gas to keep the clutch engaged for the engine brake to work .:cool:
/ Best engine braking UTV #29
the first thing you want with your new beast is a windshield and a Roof . i bought mine and it did not come out of the shop till it had the windshield in it ,,,,,,you will like it a lot better .there colder then hel( with out one ...:thumbsup:
/ Best engine braking UTV #30
ya'll know this is a 3 yr old dead thread?
Regardless I can add my 2014 ranger does tranverse our 38 degree lake lot ok. Wish it had engine braking like my Honda Rubicon but it works ok
/ Best engine braking UTV #31
Yes, to keep the clutch engaged on machines like the Ranger you need to keep the RPM's up. With a load going down hill I would have to keep one foot on the gas pedal to keep the clutch engaged and the other foot on the bake pedal just in case the clutch didn't "brake" the machine enough - which was often. The HST is a far superior way to go if you intend on hauling loads down hills!
/ Best engine braking UTV #32
I have experienced this same problem on the Kawi Mule. We have one big hill and I hate to ride the brakes going down the hill.
I can't understand for the life of me why someone doesn't build a proper ATV. Gear transmission, nothing complicated, like maybe a Ford Pinto transmision (Like the Cushman truckster had) , although you would need a transfer case of some kind, and then nothing smaller then 15" wheels. This belt driven stuff belongs on snowmobiles! Maybe like one of those Suzukis from the eighties, just stipped down for farm use.
/ Best engine braking UTV #33
Threads never die on TBN! Old info is sometimes very valuable.
My UTV doesn't have an engine, it has a 30 horsepower three phase AC induction motor.
It has motor braking going downhill, it actually charges the batteries with the energy developed from the pull of gravity. :thumbsup:
http://www.tractorbynet.com/forums/atvs-utility-vehicles/287792-electric-polaris-ranger.html
2020 Cushman 1200X Gas Utility Cart (A66734)
2020 Cushman 1200X...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2013 C&M TRAILER CHLORINE DIOXIDE MANIFOLD TRAILER (A67714)
2013 C&M TRAILER...
Engine Stand (A68134)
2015 Bombardier Evinrude 200HP Outboard Boat Motor (A66738)
2015 Bombardier...
