Best choice for engine heater CK 30 (block, heater hose, magnetic?)
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #21
Just curious, what's your nearest Kioti dealer pricing out a block heater for?
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #23
Mine still cant find it so I gave up. They say they only have a heater hose one.
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #24
I can pm my dealer to you and he can drop ship it to you. It was $68 this past spring.
The closest dealer to me is Moores Corners in New York State. They quoted me $130 for the part. I blanched.....if it is $68 I would put one in two shakes of a lamb's tail.
DOC
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #27
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #28
jabelding:
Please let me know how the install goes.
Do you use an adhesive on the bushing? I imagine a press fit is difficult to secure without an arbor press.....and really hard to secure on the tractor.
Mine is a CK 30....are the freeze plugs the same size?
DOC
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #30
I will let you know how the install goes. I have a Toyota sealant that most people have recommended. Amazon.com: Genuine Toyota Fluid 00295-00103 Formed-in-Place Oil Pan Gasket - 3 oz. Tube: Automotive
It doesn't hold in the bushing the press fit does that, just will seal any small scratches that might leak. I will just tap it in with a long bar and hammer like the others have. Also i want to be sure at full press in depth there is not contact between the bushing and cylinder wall.
I think most of the Kioti engines over 25hp are 32mm freeze plugs.
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2017 Ford F-450 Service Truck w/ Liftgate (A56858)
2017 Ford F-450...
2003 Sailfish 188 18ft. Boat with S/A 20ft Boat Trailer (A55853)
2003 Sailfish 188...
Warehouse Shelves (A56469)
Warehouse Shelves...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
