Best chain saw
/ Best chain saw
More reading and more asking questions and looking seriously at what I do and my age have led me to this decision. First, this was all started as I jumped a chain on my ECHO CS 400 with 18 in bar pushing it too hard and possibly binding it. So I go looking for a bigger saw. Here is where my age and ailing back comes in, I do want more power but not a saw so heavy that it would be tiring and or stressful on an already bad lower back. First, I am changing out the bar on my CS 400 from an 18" bar to a 16" bar thus adding slightly more power to the saw. Second I decided that 50 CC would be a nice complement to my 40cc CS 400 adding more power and still basically an 11 lb saw. My dealer tried to find me a Stihl MS 260 p;ro but they are all gone. I will check with him Monday about what deal he can make on the replacement the MS 261. He has a MS 260 (not the pro) in stock and also a ECHO CS 530 both discontinued saws. Depending on the price of the MS 261 I will see what discount he will make on either the CS 530 or the MS 260, either one with and 18" bar . Either should give me a stable of saws to handle all my needs. A bigger saw would be nice but all things considered probably not needed. Comments and thanks to those that have offered suggestions during this process.
/ Best chain saw #62
I have 2 Echo saws in my stable, both of them you mention. The 530 and the 600P. Both are very good. The 530 is an exceptionally nice saw to use, very light and capable. If you have a bad back it would be a dandy. The 600P is of course larger and heavier, easily the equal of my stihl 360 pro.
I at one time was a staunch supporter of stihl saws. That has changed and now I buy Husky, Dolmar/Makita or Echo saws. And I have No regrets.
That 530 Echo with a basic muffler mod and properly tuned is a little screamer! And a peach to handle to boot!
/ Best chain saw #63
The best chainsaw is one that starts and runs and has a sharp chain! Seriously go with the one that has a good dealer close to where you live. I have several Stihl saws and like them, the flippy cap issue has been fixed with the newer saws. The main issue with the older caps was the material in the o ring would swell and make the cap hard to operate. If you have a problem with one take to your Stihl dealer along with the serial number of the piece of equipment and they should replace it as there has been a recall on some of the older caps.
Steve
/ Best chain saw #65
Just like tractors there are different saws for different applications, I have a small stihl ms170 with 16" bar for small projects, great saw for the money, I also have a Husky 371xp with a 20" bar and skip tooth chain for firewood and bigger projects, good size saw with lots of power!
/ Best chain saw #66
I like Dolmars:D
That's a nice collection of saws you have there though.
Thanks LD1, I really enjoy using them. I would really like to use a 7900 sometime but unfortunately there are no real dealers close to me
Steve
/ Best chain saw #67
Steve
You really dont know what you are missing.
In wood 20" and smaller, it is just as quick as my buddies 660. And much lighter.
It is a absolute beast to run. I dont know how it compares to a 441 in the real world, because I havent got my hands on one, but it will eat the 044 and 046mag everyday in anysize wood.
I might get me an 066/660 one of these days and dress it with a 36" bar.:thumbsup: Its not too often we get into stuff that big, but when we do, a big saw would be nice.
/ Best chain saw #68
Funny, I am the opposite. I ran Huskies for 30 years, but after losing the crank prematurely in my 346 & my brush saw, I now own an Echo 520 and a small Stihl 0180 for brush work.
The Echo was comaprable to my 346 but $200 less, has already lasted twice as long and is still under warrantee.
The only thing I don't like is the paper air filter, but that's a pretty minor complaint. I bought the Stihl used from the dealer, I like it when it's running but it seems to have a clogged gas vent.
Like tractors though, a good dealer is the deal maker when buying a saw
/ Best chain saw #69
Well there is a good reason the 7900 has more power than a 441 or a 460, it has a bigger engine. The 7900 is 4.8 ci and 6.3 hp according to Dolmar specs. The new MS441 CM is 4.3 ci and 5.6 hp; the 460 is 4.7 ci and 6.0 hp so the 7900 should cut faster. As to it cutting faster than a 660, I am sure it does in small wood as my 441 will cut as fast or faster than my 660 in smaller wood as long as both are using 7 pin sprockets. In big wood with the 36" bar buried, the 660 really shines and shows it's stuff. I am just a firewood cutter and I like to drop and work up big trees, 40+" diameter, so the 660 comes in handy
Steve
/ Best chain saw #70
Steve
Thats all I am too brother:thumbsup:
I was comparing the 7900 to the 441 and 460 because you mention you have not ran the 7900. And I assume you have ran them stihls. And they are the closest in size.
But a bigger engine doesnt always mean more power and faster cutting.
IMO, the 290 is a turd. And there are a lot of smaller saws that are faster. Dolmar 5100/5105, 346xp, ms260, etc.
In the chainsaw world, it is very rare that MFG,s have exactally the same sized engines in their saws. There always was and always will be a few cc's difference. All we can do is compare the ones that are close.
I didnt mean anything negative about the 441/460/660 in my post by comparing it to the 7900. You just mentioned that you would like to run a 7900, and I was trying to give you an idea where it stacked up against the saws you have ran. I have ran the 044, 046, and a 660. But not the newer 441 yet. And my post is how I feel it compares to those models.
/ Best chain saw
First, thanks to everyone that offered comments/ suggestions. I brought home an ECHO CS 530 today as a stable mate to my CS 400 that I do like. My dealer, who also sold and services my Kubota BX 25 and my ZD 1800 plus the many other lawn and garden power tools i have bought gave me a great deal on the now discontinued CS 530. As I mentioned before also after using a chain saw for over 45 years I invested in a pair of chaps and face guard/ helmet. Don't want to press my luck after al lthese years of doing just that. Thanks
/ Best chain saw #72
check 6;2700482As I mentioned before also after using a chain saw for over 45 years I invested in a pair of chaps and face guard/ helmet. Don't want to press my luck after al lthese years of doing just that. Thanks[/QUOTE said:
All good safety equipment. Great insurance against some prevalent chainsaw massacres.
If you add a chainsaw vest you will complete your safety suite, almost.
The vest protects against several of the typical chainsaw "OOPS."
These include but are not limited to: lower neck where helmet doesn't help, collar bone area at top of shoulder, chest, etc.
Even with the addition of a vest you aren't totally safe.
Oh, don't forget the hightop chainsaw safety boots either.
I have all this stuff but... the single most important safety item when chainsawing is a clear head thinking about what you are doing.
Good luck. Be safe out there.
Pat
/ Best chain saw #73
stihl all the way better product i think but make sure its the 2 stroke which is the gas and oil mixture cause the new 4 stroke motors on any equipment isnt good and i have read bad reviews about um
/ Best chain saw #74
I like Echo, best easyist starting saw der is.:cool:
/ Best chain saw #75
MS260 is a great saw if you can find a new one, Buy it.
You need 3 saws in my book.
My list is the
460 magnum with two port muff 36" bar, big tree saw
Ms260 pro with 20" bar, general use
Ms200 rear handle for delimbing pro saw
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
2013 INTERNATIONAL DURASTAR 10 WHEEL FLATBED TRUCK (A64278)
2013 INTERNATIONAL...
Set of 4 Forerunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Set of 4...
2014 BOBCAT T870 SKID STEER (A65053)
2014 BOBCAT T870...
GEN POWER 40KW GENERATOR (A64278)
GEN POWER 40KW...
