Best Box Blade
/ Best Box Blade #1
Setteduke
Great Valley, NY
Ford 2120 1995. Kubota 900UTV. Ford 555D 96
I bought a six foot box blade from TSC, I have a Ford 2120, after a few years I have had to replace multiple cat pins, both sides, keep bending them and the supports of the box blade are bent. I was looking at the King Cutter and the supports are solid steel. Looks a lot sturdier. I have a lot more work to get done. Don’t want to replace the CAT pins every time and maybe the supports. Get a better box blade or beat the s out of this one? What do you guys think? I have a lot of rocky soil. Thanks
/ Best Box Blade #2
Rocky soil can be real hard on box blade. I bent the top link on one of my tractors year ago on unyielding rocks. You might be best served fixing and patching the old one.
/ Best Box Blade #3
If your pull/lift pin is mounted to a single arm with a pin that has a nut to hold it on, I would suggest adding a second pull arm and use a through pin. That way, you are pulling from 2 points on each side, rather than one.
Hope this makes sense.
Go to the 360 degree view. You can see what I'm talking about in the picture. You could run the extra arm all the way to the rear like the other.
/ Best Box Blade #5
I have a 72" bush hog brand box blade that I have beat the crap out of in my rocky soil. Other than paint it still looks like the day I got it almost 20 years ago.
/ Best Box Blade #6
I was going to order a TS one...but for a few hundred more the EA one would be much better.
/ Best Box Blade #7
Do you have the draft control engaged? If so, check if there is a lighter setting. That will enable it to lift instead of bending things.
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2020 Cushman Hauler 1200X Gas Utility Cart (A64553)
2020 Cushman...
Pull Behind Sprayer (A65640)
Pull Behind...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
