Best battery ever!!
/ Best battery ever!! #1
hillslider
MN
Kubota L3130 JD X750 and X350
I bought a brand new L3130 in 2001. correction.....purchased it 5-28-03. I don’t use it a lot...tractor only has 620 hours on it. Last night I went to plow and it was the first time ever it failed to start. I can’t believe the battery lasted 18 years. Correction.....15 years 7 months 9 days......to be exact
/ Best battery ever!! #2
18 years is remarkable for a Kubota battery. The longest I've ever had one last is 12 years. Replacement batteries have been a big disappointment. Even using Kubota batteries, the best I've done so far is 8 years.
This seems to be the case with any vehicle battery. Replacements, even OEM batteries never last as long as the original.
/ Best battery ever!! #3
My Kubota battery lasted 6 years. 18 is amazing. Do you keep a battery tender on it since you don't use it a lot?
/ Best battery ever!! #4
As I'm reading this thread, we have a Dodge Charger that is twelve years old and still has the original battery. Bob
No I don’t.
/ Best battery ever!! #6
I bought a brand new L3130 in 2001. I don’t use it a lot...tractor only has 620 hours on it. Last night I went to plow and it was the first time ever it failed to start. I can’t believe the battery lasted 18 years.
I can't believe it either!
If it were me, it would be that I had actually replaced the battery 9 years ago, and had forgotten that I did so.
/ Best battery ever!! #7
You keep it inside though, right? The cold and infrequent use would kill it otherwise. Still 18 years is darn good.
/ Best battery ever!! #8
Thought the 3130 didn't come out till 2003. (2003-2007).
Still very good battery life.
My original battery lasted 11 years.
/ Best battery ever!! #9
I bought a brand new L3130 in 2001. I don稚 use it a lot...tractor only has 620 hours on it. Last night I went to plow and it was the first time ever it failed to start. I can稚 believe the battery lasted 18 years.
18 years is a long time. I it were me I would question myself, wondering if I changed the battery sometime in the past and forgot! :D
Actually, I am serious...:eek:
Edit: I think I got about 15 years on the battery in my BX2200...Don't remember ever changing it...I changed the battery in my B2910 one time in about 16 years.
/ Best battery ever!! #10
My 2005 B7800 still has the original battery, only has 568 hours on it.
Tractor is parked in an unheated garage, when temps are below 20 degrees I use the block heater about 1/2 hour before starts.
I've never put a battery tender on it.
/ Best battery ever!! #11
i replace my battery on my bx 1830 2005 705 hr on it and the battery was still starting the tractor but did not trust it so put a new one kubota battery
The tractor has lived in various equipment sheds and barns. No heat but kept out of the elements.
/ Best battery ever!! #13
I believe you’re correct. Now you have be racking my brain. It was a new model. I remember the dealers all saying how the Grand L series is all new. So now I’m try to find the purchase receipt.
/ Best battery ever!! #15
When I was shopping tractors and purchased in 2001, I looked at the Kubota 3010 and 3410.
I'm almost sure the 30 series were not out yet.
So I finally found my receipt of purchase.....I was wrong. I did not purchase it in 2001 as I thought. I purchased it 5-28-2003. So thanks for the replies that directed me to my error. Still darn good for the battery to last so long. Now to decide what I should replace it with. Batteries have gotten expensive!
/ Best battery ever!! #17
You guys have me feeling inferior. I get excited when mine goes past 5 years! First one died at 3. And you're sure right about the cost - batteries have gotten very expensive!
/ Best battery ever!! #18
My 2006 L3400 is still purring. It's in my unheated pole barn. Next month will be 13 years with me..
The 2007 L5240 is doing the same. I thought I lost it last weekend, but it ended up being the positive terminal. It had cracked on the back of the terminal strap.
I will admit that I've been using a harbor freight float charger intermittently on the two of them since 2016. Both machines have quick connects. I usually do this if they are going to sit more than a week at a time without use, like during hunting season.
/ Best battery ever!! #19
A Harbor Freight float charger is UL approved, or China approved?
/ Best battery ever!! #20
Pretty much all of them are made in china, but they aren't all of the same quality...
I buy "Battery Tender" brand, and they have been very good lasting a long time.
BTW, the new Deka batt I put in my tractor this last summer, it had to be replaced a couple weeks ago. At least it was under warr., we will see how long this one last.
SR
2022 CORMIDI C85 STAND-ON MINI DUMPER (A62129)
2022 CORMIDI C85...
2015 Ford Fusion AWD Sedan (A61569)
2015 Ford Fusion...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
New/Unused Landhonor Quick Attach Hydraulic Pallet Forks (A61166)
New/Unused...
