Best battery ever!!
/ Best battery ever!! #1
hillslider
MN
Kubota L3130 JD X750 and X350
I bought a brand new L3130 in 2001. correction.....purchased it 5-28-03. I don’t use it a lot...tractor only has 620 hours on it. Last night I went to plow and it was the first time ever it failed to start. I can’t believe the battery lasted 18 years. Correction.....15 years 7 months 9 days......to be exact
/ Best battery ever!! #2
18 years is remarkable for a Kubota battery. The longest I've ever had one last is 12 years. Replacement batteries have been a big disappointment. Even using Kubota batteries, the best I've done so far is 8 years.
This seems to be the case with any vehicle battery. Replacements, even OEM batteries never last as long as the original.
/ Best battery ever!! #3
My Kubota battery lasted 6 years. 18 is amazing. Do you keep a battery tender on it since you don't use it a lot?
/ Best battery ever!! #4
As I'm reading this thread, we have a Dodge Charger that is twelve years old and still has the original battery. Bob
No I don’t.
/ Best battery ever!! #6
I bought a brand new L3130 in 2001. I don’t use it a lot...tractor only has 620 hours on it. Last night I went to plow and it was the first time ever it failed to start. I can’t believe the battery lasted 18 years.
I can't believe it either!
If it were me, it would be that I had actually replaced the battery 9 years ago, and had forgotten that I did so.
/ Best battery ever!! #7
You keep it inside though, right? The cold and infrequent use would kill it otherwise. Still 18 years is darn good.
/ Best battery ever!! #8
Thought the 3130 didn't come out till 2003. (2003-2007).
Still very good battery life.
My original battery lasted 11 years.
/ Best battery ever!! #9
I bought a brand new L3130 in 2001. I don稚 use it a lot...tractor only has 620 hours on it. Last night I went to plow and it was the first time ever it failed to start. I can稚 believe the battery lasted 18 years.
18 years is a long time. I it were me I would question myself, wondering if I changed the battery sometime in the past and forgot! :D
Actually, I am serious...:eek:
Edit: I think I got about 15 years on the battery in my BX2200...Don't remember ever changing it...I changed the battery in my B2910 one time in about 16 years.
/ Best battery ever!! #10
My 2005 B7800 still has the original battery, only has 568 hours on it.
Tractor is parked in an unheated garage, when temps are below 20 degrees I use the block heater about 1/2 hour before starts.
I've never put a battery tender on it.
/ Best battery ever!! #11
i replace my battery on my bx 1830 2005 705 hr on it and the battery was still starting the tractor but did not trust it so put a new one kubota battery
The tractor has lived in various equipment sheds and barns. No heat but kept out of the elements.
/ Best battery ever!! #13
I believe you’re correct. Now you have be racking my brain. It was a new model. I remember the dealers all saying how the Grand L series is all new. So now I’m try to find the purchase receipt.
/ Best battery ever!! #15
When I was shopping tractors and purchased in 2001, I looked at the Kubota 3010 and 3410.
I'm almost sure the 30 series were not out yet.
So I finally found my receipt of purchase.....I was wrong. I did not purchase it in 2001 as I thought. I purchased it 5-28-2003. So thanks for the replies that directed me to my error. Still darn good for the battery to last so long. Now to decide what I should replace it with. Batteries have gotten expensive!
/ Best battery ever!! #17
You guys have me feeling inferior. I get excited when mine goes past 5 years! First one died at 3. And you're sure right about the cost - batteries have gotten very expensive!
/ Best battery ever!! #18
My 2006 L3400 is still purring. It's in my unheated pole barn. Next month will be 13 years with me..
The 2007 L5240 is doing the same. I thought I lost it last weekend, but it ended up being the positive terminal. It had cracked on the back of the terminal strap.
I will admit that I've been using a harbor freight float charger intermittently on the two of them since 2016. Both machines have quick connects. I usually do this if they are going to sit more than a week at a time without use, like during hunting season.
/ Best battery ever!! #19
A Harbor Freight float charger is UL approved, or China approved?
/ Best battery ever!! #20
Pretty much all of them are made in china, but they aren't all of the same quality...
I buy "Battery Tender" brand, and they have been very good lasting a long time.
BTW, the new Deka batt I put in my tractor this last summer, it had to be replaced a couple weeks ago. At least it was under warr., we will see how long this one last.
SR
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
2018 Caterpillar 308E2 CR Excavator (A61166)
2018 Caterpillar...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2025 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
