Best and worst chainsaw?
   / Best and worst chainsaw? #241
I have had the same Stihl Farmboss saw for about 30 year. It has had to have a couple trips to the shop for tuneups and minor repairs, mainly to the fuel lines because they tend to break down over time. My expaierience is that it is not so much the saw as the chain you use. I bought a couple of "consumer grade" safe chains that would burn through a log faster than cutting it. A logger friend told me to go to a pro shop and ask for what he called a "skip tooth" chain. He said I would have to be careful or it would tear me up, but it cut through the same logs extremely fast and smoothly. Also, keep your chain sharp. Like a dull knife, a dull chain is much harder to deal with.
Skip tooth has half the cutters that a normal (full complement or full comp) chain has. Semi skip is in between. Basically, a full comp chain has 1 cutter for every 2 drive links, a semi skip has a cutter for every 3 drive links, and a full skip has a cutter for every 4 drive links.
I think what you are talking about is full chisel chain. The cutter on a full chisel chain comes to an actual point. The leading edge on a safety chain forms a curve as it transitions from the gullet (side plate) to the top plate. Semi chisel is very similar to a full chisel but it has a slight radius instead of a point. Full chisel is the most aggressive. There are all kinds of videos showing that it's no faster than a semi-chisel chain, but those folks don't know how to correctly sharpen a full chisel chain. Properly sharpened, a full chisel chain is noticeably faster. Having said that, it also dulls faster than a semi chisel chain, and as soon as it starts to get dull, its advantage goes away. That means A) ALWAYS keep it out of the dirt and B) Sharpen it every time you fill up the tank with fuel. The sharp point that makes the chain cut faster also makes it a LOT more "grabby" meaning that it will kick back on you a lot more than other chains. It also pulls itself into the wood more, so don't lean on the saw when its cutting. Let the saw and chain do the work, and for crying out loud KEEP BOTH HANDS ON THE SAW AT ALL TIMES. If you don't know why, then you don't have enough experience to know when either.
If you're cutting wood that has a lot of dirt in the bark (from skidding it, or wind blown into it), or if you don't sharpen after every tank of fuel, or if you take your chains to the dealer to be sharpened on a grinder (ugh, that's a painful thought), then semi-chisel is probably better for you. The initial contact area is spread out a little more than it is on a full chisel chain, so it doesn't wear quite as fast and can last a little longer between sharpenings (2 to 3 tanks of fuel max). Actual safety chain is a waste of time and $$ in my opinion.
Odds are, if you think your saw cuts slow, its because your chain isn't actually sharp, or hasn't been sharpened correctly. The advantage of a pro saw can quickly be erased by a chain that's not as sharp as it could be.
   / Best and worst chainsaw? #242
Based upon the above, my choices are evaporating. I do not possess (nor need whatsoever based upon our now current and foreseeable future residence: HOA does all maintenance) any battery powered lawn equipment. My battery powered tools have much lower/smaller design & capacity than chainsaw requirements. And, since the point of use could be years in the future, there is zero confidence that the batteries will still be health upon the "break-glass" intent for use.
That battery dynamic, with the rubber rot on a gas powered model makes my concept of an emergency-unused device problematic.
If you're in an HOA, being prepared for a disaster is a pipe dream. Even if you had a working saw, cleaning up downed trees after a storm is one of the most dangerous things you can do. I've hung my share of trees while felling firewood, but I've never come close to the stuff that we've dealt with doing disaster cleanup. Not even close. My primary rule for doing this kind of work is the damage is already done so there's no reason to get yourself hurt trying to clean up the mess. My 2nd rule is don't be braver than you are smart. Based on what I've see, there must be some REAL geniuses out there....
   / Best and worst chainsaw? #243
I will start cutting firewood in the coming months which made me wonder, "what's my best and worst chainsaw?" I'm not extremely picky on brands but my experience with Echo is mixed and is limited to one model with Stihl. Aside from a basic homeowner, inexpensive poulan I've had 3 chainsaws.
My first "farm/commercial" grade purchase was the echo cs590 "timberwolf." Bought it bout 9 years ago (?). My favorite saw. 20" bar and cuts everything I've thrown at it. I've cut firewood: we heat our home with a Lopi wood stove. I've trimmed trees and cleared well over 1,000 cedar off of 70 acres. This saw is my favorite. It's a bit heavy for trimming and clearing cedars.
I wanted a lighter saw so, I stuck with Echo and bought the 4510 with an 18" bar. This saw never ran right. Finicky bout idling. I struggled with it for a few months. My dealer (who is great) tweaked it. Ran a bit better. I even started buying the echo premix fuel. I've always used premix but upgraded to echo's red "something." Somehow, that saw burned up and I threw it away after less than a year. The dealer said water somehow got in the fuel. I'm not sure how that could have happened. Regardless, I never liked the saw so I didn't press it.
I then picked up the Stihl ms250 with an 18" bar. This is a great saw. Lighter than the echo. And, starts a bit easier. But, it doesn't cut as efficient. I use both saws and appreciate them. The cs590 remains my favorite. It just cuts so dang fast and sometimes the weight works for me. Even when I'm sawing cedars horizontal the speed may offset the weight.
I do want a new saw. I'm thinking about a new cs590. What's your experience for best all around saw. By all around, I mean firewood and property mtnce (clearing cedar, fenceline cleaning, even cutting brush and underbrush).
In 35 years of using chainsaws, Power to weight ratio has been a huge issue for me. For storm cleanup, clearing fence rows, cutting firewood my stihl 036 pro (now the 362) has been my go to.
I have had smaller saws that have been good for light work, but my Stihl has been great.
I just added a 462 with 32" lightweight bar for big work. A Stihl 261 would be a fantastic lightweight, high performance saw for most firewood tasks.
Husqvarna makes great saws too. Slightly heavier than their Stihl pro series counterpart, but very high quality.
My .02
   / Best and worst chainsaw? #244
The primary purpose for the saw is emergency travel/egress. I am talking about the need to move a downed tree off of a road using a saw, winch/tow chains; make it smaller, pull it out of the way. BTDT, but during that time the tools were in frequent use, not dormant storage. My background includes 40+ years of professional emergency service for very large public safety agencies. "Disasters" were the daily job.
   / Best and worst chainsaw? #245
growing up on the farm my dad and grandpa had to Poulan chainsaws. They seem to run pretty good. My grandpa took care of them. When I purchased chainsaws for my place. I went with stihl 271. Its pretty light which i was pleasantly surprised. I purchased a carbide chain for it. The carbide has been great. I have a smaller stihl but I rarely use it.
As for what brand to get. Personally id go with what works and which has a good reputation. Especially if your gonna use it often. Thats how I determine if i go name brand or cheap. Most of my tools are cheap bc i dont use them often enough to worry about breaking them. Chainsaw needs to run b/c I cut a lot of wood
   / Best and worst chainsaw? #246
An axe and a crosscut saw are reliable. No gas, no batteries. Make sure the axe has a synthetic handle.
   / Best and worst chainsaw? #247
Stihl is pretty much dominating right now. If you really want a nice saw, see if you can find a German made Dolmar before Makita moved the operations to China. Their 5100 series was a 14,500 RPM saw. There are 60cc too all the way up to 90cc
The 6400-7300-7900 and the 9010 were German made all the way up to the stop of production. The smaller saws were german manufactured but assembled in China. The 5100 was a failure of a saw, and as a dealer we were told to turn them down to 13,500 due to the high revs were burning them up. The early 5100's were 14,500 but later versions prior to the 5105 were reduced to 13,500 with rev limited ignition modules. Also the 5100 had issues with dirt ingestion around the air filter sealing surface and were showing signs of cylinder and piston damage.
   / Best and worst chainsaw? #248
We have several Stihl MS 250’s and they have been very good saws. Aside from our Stihl fleet of chainsaws, we have been buying Echo Chainsaws recently. It’s hard to beat IMHO Echo for the price and feel they make great 2-cycle engines.
We have a 620PW which would be close to the 590.
My recommendation is go with a 50cc saw as a companion to your 590. We have a 501P and like it. I feel the 4910 is a better value and with a few exceptions, pretty much identical to the 501P. You might still find a 4910 at Home Depot or a dealer.
Another saw Echo recently discontinued is the CS400. If you look, you can still find a left over. They are a great saw too. We have one of these too.
Best of luck!
   / Best and worst chainsaw? #249
I own stihl all the way. 3 chain saws a 180, 250 and A 440? Also a blower and demo saw. The 250 is not a bad saw always cuts good for me but the 440, not sure of the exact model #, cuts like a monster even with a dull chain. All my equipment is older and has needed minimal maintenance.
   / Best and worst chainsaw? #250
I currently have two 20+ year old Husqvarna saws. A 20 inch 460 and an 18 inch 350. Both of these units start very easily every time and run like they did when I bought them. These units are amazing tools that allow me to work on my project rather than work on a saw.
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
2006 Toyota Prius Hatchback (A56859)
2006 Toyota Prius...
2015 Peterbilt 320 Heil 28Yd Side Loader Garbage Truck (A55973)
2015 Peterbilt 320...
