Toplink Bent Top Link
/ Bent Top Link #1
Texas Dodge
Nursery, Texas
Kubota L3400 4WD
Well yesterday I was working on the driveway with the BB. I was tilting the BB some so I could crown the driveway. Had to extend my top link all the way to hook back up to the BB. When I lifted the BB, then end of the top link with the threads closest to the BB bent. Can I buy just the one threaded end a TSC and not the whole top link?
/ Bent Top Link
/ Bent Top Link #3
I don’t know if they sell just the ends a TSC but the last top link I bought there was under $25 dollars so it is not the end of the world. I did have to hit one end with an angle grinder to fit the tractor side of the top link hook up on my Kubota.
MarkV
/ Bent Top Link
MarkV said:
I don稚 know if they sell just the ends a TSC but the last top link I bought there was under $25 dollars so it is not the end of the world. I did have to hit one end with an angle grinder to fit the tractor side of the top link hook up on my Kubota.
MarkV
That's good to know:)
/ Bent Top Link #5
If you have to extend the TL that far just to hook up - it's too short. Rather than spending money to fix that one, why not buy the next longer size? If you still elect to replace the end, take the TL with you. You need to turn in a known good end to make sure the female threads aren't damaged as well.
Be advised also, that the opposing ends are not threaded the same. So first you want to select an end with the correct threads, THEN you want to see if it will actually thread into your TL. THEN compare the price of the replacement end - with the price of a new (longer) TL.
//greg//
/ Bent Top Link #6
I'd want to know why it bent in the first place . The top link is under tension not compression (when lifting). It must have fouled on something to make it bend .
/ Bent Top Link #7
Personally..Id repair ( buy a new end) for the screwed up link and buy a BRAND NEW top link from TSC.
I Leave each top link on the equipment ...that way I dont have adjustments to make.....when I hook up that impliment...the top link is already adjusted.
/ Bent Top Link #8
Top link for each piece of equipment!!!
It's John D. Rockefeller...:rolleyes:
/ Bent Top Link
I think what happened was I had the BB angled way too much. I got the right pin on the BB into the QH. I then had to remove the adapter and extend the top link all the way out to get it to fit back to the BB. The left pin was still approx. 3 inches above the J-hook on the QH. So I lifted the BB hoping to get the pin in the J-hook. I guess that was too much stress on the top link and I bent the one end.:( :( :(
/ Bent Top Link #10
At $20 each? You got to be kidding me?? Its the $5 a gallon for fuel to go get them is whats killing me....lol
/ Bent Top Link #11
Hey, that's 4 gallons...and if you get a hydraulic top link you won't buy anymore...:D
/ Bent Top Link
Got a new top link this morning from TSC only $23.00. This one here looks to be more of a heavy duty one than the one that came with the tractor.
/ Bent Top Link #13
You might want to save the old one for a BIY project (TNT, or rachet toplink, or partial chain toplink)
Or fix it and keep an extra around, just in case.
However, I do think you'll like the new one you bought. :)
/ Bent Top Link #14
That's why John D Rockerfeller went into oil rather than top links...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
100" Bucket (A64119)
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
7888SFL (A61567)
7888SFL (A61567)
2001 International 4000 DT 466E (A60462)
2001 International...
