Rear Blade bent scraper blade for snow removal
   / bent scraper blade for snow removal #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
It seems that many manufacturers have reverted to break bending their mold boards as opposed to rolling them to acquire a radiused surface. Obviously this is a cost saving measure which is fine if it works. Currently have a Woods with a 14" high curved scraper blade that snow rolls over constantly with an 8-10"event . I've attempted all kind of settings but with the soft snow, it just spills over. As I do not feel like spending a thousand bucks or more on a heavy duty blade that will be strictly used for snow work, I was wondering if anyone is using the bent type blade for snow and if it's working out for you. Thanks
   / bent scraper blade for snow removal #2
I have a new Land Pride blade that the snow slid off real easy. I think it is because the paint is new and slick. Maybe if you horsed the moldboard up onto the bench you could sand it smooth and give it a few coats of paint. By the time it snows again the paint will have cured nice and hard and maybe it will clean it's self out much better.
Could be Tiller. But my Mahindra 3016 with me driving it destroyed this current blade I have. Mounting bolt is broken. It even has puckers where the cutting edge bolts to. This is 1/4" thick metal with puckers. I don't know how that happened. I like the LandPride stuff but $975 before freight for the 6' RB26 was a bit rich for my blood. Can even offset it w/o unbolting the entire blade and sliding it over.
   / bent scraper blade for snow removal #4
Rear blades aren't very good for moving snow, if you look at truck snow plows they are about 30" tall and the snow still goes over the top with an 8" storm. You also need some speed to get the snow to roll especially with the fluffy stuff witch is hard to do with a tractor in reverse.
Been using a rear blade for years. Doesn't do a bad job but mostly always pull it. You are right about the speed though even moving forward. Curved blades do much better but the bent one's are cheaper. Looking for someone with experience with the bent blade for snow to see if it will suffice.
   / bent scraper blade for snow removal #6
Unfortunately I can't tell you how a bent blade will work, I have an old worksaver that is curved. I used to plow with just the rear blade and bucket but it's slow because of all the spill over whether your pulling or pushing. If snow is the only use for the rear blade then I wouldn't bother, your better off with an over sized bucket for the loader. I'm not sure how wide your standard bucket is but go with something a couple feet wider in a high volume style. You can move and stack alot more snow and in the summer it can be used for mulch, manure, and other fluffy materials. If you do have other uses for the blade my only suggestion would be get the tallest and widest that your tractor can pull, the taller the better when it comes to snow. I plow with a truck now and the best use for the back blade is garage doors! After I have most of the driveways cleaned up I open all the garage, barn, and pasture doors, then all I have to do is back in to clean them out, almost no shoveling.
   / bent scraper blade for snow removal #7
My back blade is a Land Pride with a rolled mould board. To answer your question, if it is bent, instead of rolled, I would not expect to see any major difference.
As allready pointed out, what will make a difference in snow, is the mould board height, the total amount of projected angle(of the roll, or bending), the travelling speed, the "slipperyness" of the mould board, and the relative angle of the blade from the tractor. If the blade is parallel to the tractor, the snow will bundle between the tractor and the blade in no time. The heavyer/wetter the snow, the greater this angle should be. The greater the angle, the shorter the working width of the blade. Trade offs...
I once made a front plow for another tractor by bending it. The difference was that my middle section was as long as the upper and lower section of the plow. Snow rolled nicely with this design. The bends on the mold boards of the bent scrapers are not this way. The middle section is much larger. Basically beyond that i don't know what to think. I just didn't want to invest in a new blade and run into the same problem.
It appears the safest bet is to invest in a rolled blade with a higher moldboard even if it costs a grand.
   / bent scraper blade for snow removal #9
What blade do you have? Is it a Woods RB? I use a RB60 behind the BX and snow comes over it but I do use it backwards. I use a HBL84 on the 4240 and the snow does not come over it as easily.
Do you have SSQA on your tractor? You could rig up a plow on the loader pretty easily.
It is a Woods RB72. Boy did it get mangled this year. I rigged up a snow pusher for the front end as I have spread out parking areas to plow out. The blade is for the 150' driveway part. Your HBL has good moldboard height. Where I used to have need for the rear blade for dirt work, I do not anymore so I didn't want to spend on a heavy duty unit. Unfortunately, it's these units that have the tallest blade height which is advantageous for snow work.
The Rhino 5006 has a 16"height, (which I think Dirt Dog makes for them) seems like a nice one but it too is over a grand after shipping.
The best "value" at $700 seems to be the EveryThing Attachments Deluxe blade however this is using a 2 bend blade rather than a rolled.
2015 Freightliner M2 106 AWD Versalift TMD2047T Insulated Digger Derrick Truck (A55973)
2015 Freightliner...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
LOT: (36) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #2 Grease (A59076)
LOT: (36) 14 Oz...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
2012 TALBERT 4-AXLE RGN TRAILER (A58214)
2012 TALBERT...
