Bent grapple repair
/ Bent grapple repair #23
There is a thread on Jul 9th 2018 Titled
Tweaked FEL. Read thru that thread. It is long. But several people including myself say to cut the cross tube loose to make the repair on the loader frame. Although that was not the final fix on this thread. If I knew how to attach the link I would.
/ Bent grapple repair #24
There is a difference between the loader frame, and the SSQA...
I don't know the specific thread you reference, but I have never seed a thread suggesting cutting of the loader cross tube. Which is usually a VERY heavy structural member of the loader....and even cutting it....and trying to tweak the loader wouldnt have desired results.
However, there have been may threads about cutting the cross tube on the SSQA.....since it's just a little tube and isn't structural. And only serves to index the latch boxes on the SSQA until an attachment is installed
It's your lower lid that's bent - - correct. Is it really having a negative effect on the grapple operation. If it's not - leave it alone.
When I lower the grapple the bent piece penetrates the ground before the other blades. Also keeps the unit off level causinsng difficulty mounting.
/ Bent grapple repair #28
Wonder if I heat it on the tractor then use the hydraulic and lower it onto cinder block to straighten it?
I would be very carefull - doing this. You don't want to bend/tweak something else.
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
John Deere 750C Dozer (A66285)
John Deere 750C...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
