Bent FEL Bucket
/ Bent FEL Bucket #1
LarryS
Phillipsburg, Ohio
MF GC2300
I have a GC2300 that has a bent FEL bucket. The 17 year old was using it for snow removal last winter and had the bucket bottom vertical like a plow. Long story short, it's bent about a quarter inch. Just enough to make cleaning out the pens annoying.
Any thoughts on how to straighten this? Do you think a tooth bar would straighten it? I was considering using heat as just pounding on it with a sledge produced lots of noise.
/ Bent FEL Bucket #2
Sledge will just bounce. I assume the bottom edge is bowed up or down? You need body shop/frame straightening methods. Some way to hold the ends steady and apply a steady load to the center. Many ways to do it, but if you can't think of any quickly, run it over to a body shop. They'll take care of it in five minutes.
/ Bent FEL Bucket #3
There was a thread a couple of months ago on this subject. I suck at searching, maybe you can find it. I'll try again.
Found it: cupped fel
/ Bent FEL Bucket
I finally read the reply. Sorry for the time to get back to this.
Unfortunately jacks that expand won't work. I need to draw the bottom edge up. The backhoe stabilizer idea might work out though but I need to pull the bucket off the FEL and turn it upside down.
Sounds like how any new redneck sport begins: "Hey buddy! Watch this!" I visualize FEL buckets squirting out from under backhoes from sea to shining sea.
/ Bent FEL Bucket #5
I used a farm jack - hooked it on the top of the bucket and pulled up the bottom --
/ Bent FEL Bucket #6
We work with this kind of thing in our machine shop quite regularly.If you have access to a rosebud on a cutting torch outfit you heat along the cutting edge working from the center outwards & I mean pretty warm. Heat the top side in stages & let it cool & it will shrink back to straight.Try a 6" section at a time & let it cool & you will be amased at how gradually it will pull back. Another method is to weld beads on top side of cutting edge & when it cools it shrinks & will pull back straight. Please let us know how you make out.
/ Bent FEL Bucket #7
Find a large wooden fence post and put some down pressure with the bent section of the bucket and it will straighten right up. Make sure nobody is standing close and very gingerly apply the down pressure and it is fixed. Just recognize that the metal is damaged and it will not be as strong as before you bent it. (i.e. it is more likely to bend again.) Let us know how things go!
/ Bent FEL Bucket #8
Can't say that I have ever seen one straightened like that. Normally the only thing that will happen is that the front wheels will come off the ground.;)
/ Bent FEL Bucket
Well I tried that almost right off. The wheels did just come up evidently not enough weight on the front of a GC2300.
Looking at this bucket further, I note the front sacrificial edge is what is really bent/worn down. How hard is it to replace these things? It's continuously welded across the bucket. I think if I had that off, the bucket would straighten up much easier as the sacrificial edge is more than half the metal thickness.
LarryS
/ Bent FEL Bucket #10
If you have a good welding or fabrication shop in the area, take your bucket off and take it to them. It won't take them long to fix and it shouldn't be very expensive either. They may even have replacement edges in stock if want it replaced.
/ Bent FEL Bucket #11
My neighbor has the same tractor and did the same method of plowing and bent his. We placed a 6x6 block of wood under the center and the two of us jumped up and down on the outer edge of the bucket. (we weigh about 240 ea.) It straightened his bucket out. If you don't have a couple of big guys you could also try the same 6x6 in the center and lay a couple 2x6 out from the bucket edges and drive a car / truck onto them to push it back into alignment.
/ Bent FEL Bucket #12
I have been thru this several times. If the bucket is not
bent too bad, then I use heat, hydraulic jacks, come-alongs,
and a sledge hammer.
Pictured is a JD bkt that was too far gone, and work-hardened
from previous repair attempts. The carcass is only 1/8" thick.
My local tractor dealers had weld-on cutting edges, but they
wanted $300 for a 6-ft piece. I found a chunk of beveled plow
steel at a steel dealer for $60.
/ Bent FEL Bucket #13
And here is the result. I cut out the top edge and the whole
bottom plate with a plasma cutter and welded in the sched 40
pipe for a strengthened top lip. I welded in a new piece of 1/8"
x 10" steel for the bottom, along with the 1/2"x6" plow steel.
Managing the heat is important to avoid warpage. No continuous
welds.
The resulting bkt for a JD 955 is better than the original was new.
/ Bent FEL Bucket
I really like the pipe idea. Fortunately the FEL on my GC2300 has a good strong top to it.
Looks like the edge needs to be cut off. Time to let my fingers do the walking to find a fab shop.
Thanks for everyone's suggestions!
2014 Blu-Jet AT3000 Applicator (A66285)
2014 Blu-Jet...
4004SFL (A59228)
4004SFL (A59228)
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
2003 Jeep Liberty 4x4 SUV (A64557)
2003 Jeep Liberty...
