Bent exhaust pipe!
/ Bent exhaust pipe!
firemanpat2910 said:
since you are so close to the end of tail pipe anyhow, would the exaughst bother you if you just cut it off before the bend? If you angled the cut to blow down, or out to one side? This way its shorter and you can go back in the same spot and not bend it again:D :D . I couldnt tell from the pics if it realy needed to be that long. I shortened mine because it always blew in my face when hooking up the 3 pt pins.
All good questions. I assume NH engineers dumped the exhaust at that site (under the left side step) as a "compromise". I wonder if I take the pipe to a muffler shop if I can get a new pipe that dumps straight down at the same site as the bend? I wonder of being dumped straight down would blow alot of "dust" into the air? Questions and more questions! At least the pipe would be less vulnerable.
Bob
/ Bent exhaust pipe! #22
How about dumped down, but then with a slight flair to the rear.. just like a car exhaust.. etc.. so the exhaust vents out horizontal, just after the 90' bend.
Soundguy
Well, after all the excellent advice here, I removed the bent exhaust and atttached a 18 inch flexible exhaust pipe. I am happy to report that the tractor runs fine. The exhaust is "clear" (no obvious smoke or particulates) and although the pipe gets hot, the exhaust is remarkably cool at the tip. After running it for an hour on a cool day (40 degrees) none of the adjacent parts get warm (the oil filter does, but that is to be expected). If the flexible pipe was 6 inches longer, it would clear the frame completely and might even be a permanent solution :D . Maybe some nice black exhaust paint and no one would ever notice?
/ Bent exhaust pipe! #24
Bob while you're crawling around under that TN messin' with the exhaust system why not go the double, chrome, vertical pipe set-up. That baby would sound mean and howl when you put her to work.
/ Bent exhaust pipe! #25
Bob,
One of the most annoying thing on my CUT is that the exhaust pipe pointed down just behind the front tires. When it's dry and dusty outside, the exhaust would be like a fan blowing down, which caused the dust to fly up. It got so bad that I stuck a crow bar into the end of the tail pipe and just pulled as hard as I could to turn it out.
It's either soft metal or it was hot enough to bend, because I was able to put enough turn into the pipe to have it exit the side.
I would never own a tractor that sent it's exhaust straight down, but from the looks of your setup, you can fix it pretty easy when things dry up and get dusty.
Eddie
Chrome :D ! Sounds nice. Maybe hang some nice nice on the dash while I am at it with the chrome pipes :). One friend described my flex pipe solution as "ghetto". I will dry fit the new pipe next week and see what happens. IF all goes as planned, I will have the bent pipe fixed and then have a spare I will never need since I will not reuse the 4 inch extension and therefore never bend another exhaust pipe.
Bob
VWS Toolbox/Fuel Cell (A61166)
VWS Toolbox/Fuel...
CATERPILLAR 305E2 CR EXCAVATOR (A62129)
CATERPILLAR 305E2...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
Golf Cart (A60352)
Golf Cart (A60352)
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
